Ecu Change
1497 replies to this topic
#1281 chris_uk
Posted 11 June 2014 - 08:08 PM
yea i dont have the sandwich plate like lee.. mine is just normal..
#1282 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 07 August 2014 - 06:59 PM
well another big day I used it for work yesterday and today, been doing some ign/knock on both runs seems to be going good, next is the WI kit got to find my MAF I had and get it hooked up.
#1283 NickB787
NickB787
  • 7,813 posts
Posted 30 August 2014 - 04:47 PM
I will drop this here so I don't fill the other forum I am wondering if it may be real, possible secondary fuel pump failure? going to 20 at @3500 rpm the returning to 10 when off the throttle.. power doesn't seem down though!!', I went back to the last good map before I advanced the ign and when I did a power run it was the same AFR upto 20. Seems sensible
Edited by NickB777, 30 August 2014 - 04:48 PM.
#1284 CHILL Gone DUTCH
Posted 30 August 2014 - 05:10 PM
Double check the setting for wideband in the settings tab May of reset it self This can happen when you save the program file into a diffrent place because the run file isn't with it
#1285 NickB787
NickB787
  • 7,813 posts
Posted 30 August 2014 - 06:39 PM
no checked that and the information about the wideband is correct.
#1286 NickB787
NickB787
  • 7,813 posts
Posted 02 September 2014 - 01:01 PM
Seems to be a problem with the wideband. hope it's not the controller will check it out, put a hold yet again on mapping, really want to get it sorted so I can turn on the water injection and see how much of a difference that will make. would I need to do a fuel learn session again with WI?
#1287 CHILL Gone DUTCH
Posted 02 September 2014 - 01:39 PM
Are squirting WI before the Tmap sensor ?? Just thinking out loud, Would of thought the WI would be same fueling just cooling air but if you were spraying after Tmap it might be diffrent story Maybe somone who has used it before might come along and comment
#1288 smiley
Posted 02 September 2014 - 02:21 PM
It's not as if he's injecting methanol or anything, as that's a different story.
All the water does, is take temp down, as if it's 10 degrees celcius out there (just an example)
And if the bottle is empty, the ecu still needs to know how to behave.
So i see no special learning for WI untill V3 of obdtuner.
#1289 Exmantaa
Posted 02 September 2014 - 02:25 PM
Which Wideband controller was that again?
Some have a free-air calibration procedure/button. Or perform such the 1st time after the controller was switched on with no sensor connected to it.
Only removing the sensor from the exhaust for this is no fun...
#1290 NickB787
NickB787
  • 7,813 posts
Posted 02 September 2014 - 03:10 PM
WI is into the manifold after the. TMAP I had wired into the TMAP but Peter recommended using a MAF which I have and will wire in. The wideband is a PLX unit I got that one because it does not require calibration in the open air.
#1291 NickB787
NickB787
  • 7,813 posts
Posted 17 February 2015 - 04:52 PM
got the lambda still to do I installed a LS4 TB today, first start ok, I uploaded the fact it was an LS4 to the ecu on start up when going to drive it I got EML, 999 temp p1514, p1523 just wondering those who have fitted the larger TB any similar issues? hope it's not a dead tb wil start searching when I get time
Edited by NickB777, 17 February 2015 - 04:55 PM.
#1292 CHILL Gone DUTCH
Posted 17 February 2015 - 05:06 PM
P1523 throttle position closed P1514 Airflow to TP Sensor Correlation High Did you make the throttle bodie type perminant in the parameters after selecting ls4 i
#1293 CHILL Gone DUTCH
Posted 17 February 2015 - 05:07 PM
Sounds like it went back to old type throttle body on second start
#1294 NickB787
NickB787
  • 7,813 posts
Posted 17 February 2015 - 05:10 PM
Just checking now almost certain I did, slow tablet
#1295 NickB787
NickB787
  • 7,813 posts
Posted 17 February 2015 - 05:30 PM
it saved it so it knows it's an LS4
#1296 CHILL Gone DUTCH
Posted 17 February 2015 - 05:37 PM
Have you tried to fire it up again ?
#1297 NickB787
NickB787
  • 7,813 posts
Posted 17 February 2015 - 05:43 PM
yep still the same, tomorrow will give the TB connector some electrical cleaner and see
#1298 CHILL Gone DUTCH
Posted 17 February 2015 - 05:51 PM
👍 Don't sell your old TB yet
#1299 NickB787
NickB787
  • 7,813 posts
Posted 17 February 2015 - 05:55 PM
Wasn't going too need to make certain the be one works and is driveable
#1300 CHILL Gone DUTCH
Posted 17 February 2015 - 05:59 PM
Is the wiring the same as 68mm
