Ecu Change
1497 replies to this topic
#1301 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 17 February 2015 - 06:20 PM
as far as I know, Lee has changed his I haven't seen any information that a rewire is required
#1302 smiley
Posted 17 February 2015 - 06:25 PM
Joe is selling broken LS4´s :sleep:
Lotus ownership is expensive :dry:
Edited by smiley, 17 February 2015 - 06:26 PM.
#1303 NickB787
NickB787
  • 7,813 posts
Posted 17 February 2015 - 06:34 PM
Joe is selling broken LS4´s :sleep:   Lotus ownership is expensive :dry:
hope not I bought mine from Joe
#1304 smiley
Posted 17 February 2015 - 06:42 PM
me too :tt:
Not fitted yet. :mellow:
#1305 Exmantaa
Not sure, but does the ls4 tb require the same wiring swsp as the lsj??
#1306 Baron Von Scubadaddy
  • 6,644 posts
Posted 17 February 2015 - 06:52 PM
:popcorn:
#1307 smiley
Posted 17 February 2015 - 06:57 PM
"Modification to the blower inlet is required or the larger throttle plate will contact the blower and not allow full opening, for the adapter plate please select Option 1"
http://shop.zzperfor...dy-for-LSJ.aspx
:mellow:
This may be interesting for you exmantaa:
**PCM calibration required. In HPT under engine idle airflow the ETC area scaler is normally 2950 (this works out to throttle plate area in milimeters less the rod area).
67.4 dia, pi*r2 = 3568 less throttle rod area (620) = 2948
75 dia, pi*r2 = 4418 less throttle rod area (730) = 3688
You'll need to change the 2950 to 3688. Many users have reported better results going even higher. We have tested numbers ranging from 3775 to 5500 without issue.
Edited by smiley, 17 February 2015 - 06:58 PM.
#1308 NickB787
NickB787
  • 7,813 posts
Posted 17 February 2015 - 07:07 PM
yes but is that not for the m62 rather than the harrop
#1309 CHILL Gone DUTCH
Posted 17 February 2015 - 07:09 PM
That's what I was led to believe Where is lee
#1310 The Batman
Posted 17 February 2015 - 07:15 PM
I have more so can replace if needed :)
#1311 Baron Von Scubadaddy
  • 6,644 posts
Posted 17 February 2015 - 07:17 PM
Are those the ones you got from your couzin Imran ?
#1312 The Batman
Posted 17 February 2015 - 07:18 PM
Yeah last name ofwithyamoney
#1313 Baron Von Scubadaddy
  • 6,644 posts
Posted 17 February 2015 - 07:20 PM
Thats the fella !
#1314 NickB787
NickB787
  • 7,813 posts
Posted 17 February 2015 - 07:40 PM
not a problem yet Joe will do some research and troubleshoot first, thanks though
#1315 oakmere
oakmere
  • 2,143 posts
Posted 17 February 2015 - 07:46 PM
Nick Is the TB sealed against the Harrop correctly? As you will see these codes if you have an air leak.
#1316 NickB787
NickB787
  • 7,813 posts
Posted 17 February 2015 - 07:52 PM
I did have to put 2 longer lower bolts on as the original 67tb ones were not long enough, another thing to check, I have never used a gasket on the join between the tb and s/c, metal to metal seal only
#1317 The Batman
Posted 17 February 2015 - 08:13 PM
Am I right in thinking the harrop has a built in gasket?
#1318 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 17 February 2015 - 08:26 PM
I think Matt Bentley took my ls4 away to work out the gasket needed between that and the harrop?
#1319 smiley
Posted 17 February 2015 - 08:33 PM
#1320 NickB787
NickB787
  • 7,813 posts
Posted 17 February 2015 - 08:39 PM
try to pull the TB off tomorrow and check if a gasket is required
