Ecu Change
1497 replies to this topic
#1381 Bargi
Bargi
  • 4,483 posts
Posted 23 February 2015 - 01:49 PM
Lee said the same.
Looks like a mandatory mod for the harrops on Dutch.
sigh... I thought I had all shiny bits required, best call the Batman! :D
#1382 Exmantaa
Posted 23 February 2015 - 03:18 PM
U.S. chaps complained it was twitchy, didn't find it so at all, worthwhile upgrade IMHO
The dutch running on HP tuners had the same.
Looks like Peter has got that area better sorted.
Never tried an LS4 TB on the TPTuners/LSJ ecu, but some US guys said the above.
Will try one soon on my engine.
Curious to see some graphs before/after, as the bigger TB will give a lot more air @ mid throttle, what can give the impression of big power improvements
#1383 smiley
Posted 23 February 2015 - 03:41 PM
Wanna borrow mine?
Can´t use it anyway till you fixed my harrop.
#1384 Exmantaa
Posted 23 February 2015 - 03:45 PM
Don't worry, I'm getting my own J-TB. :happy:
#1385 smiley
Posted 23 February 2015 - 04:10 PM
If lee´s tuner can get the map sorted, then i´m sure you can do the same I HP tuners.
Maybe the US comments are just poor hearsay.
#1386 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 23 February 2015 - 10:49 PM
I've got the ls4 to fit soon so will try to do a before and after.
#1387 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 24 February 2015 - 10:54 AM
Much better from cold, old map could be a bit finicky I found, no problems so far.
#1388 NickB787
NickB787
  • 7,813 posts
Posted 08 April 2015 - 11:08 AM
Just changed my wideband for an updated PLX gen 4 unit. PLX now use Bosch 4.2 sensors I am wondering if I need to make any changes to the OBD software for the different Lambda? anyone using this new sensor?
old settings EGR input low 00.00-10.00, EGR input high 5.00 - 20.00 with a 170ms sensor delay
new one shows measurement range 10-20 AFR 0.68 - 1.36 Lambda   form the info sheet
I decided against a gauge in the cabin so just hooked up through the ecu.
Edited by NickB777, 08 April 2015 - 11:09 AM.
#1389 techieboy
Posted 08 April 2015 - 12:00 PM
PLX now use Bosch 4.2 sensors anyone using this new sensor?
Isn't the LSU4.2 the old type sensor and newer ones are the LSU4.9? :unsure: Both the Innovate and 14point7 widebands I've got use 4.9 sensors.
#1390 techieboy
Posted 08 April 2015 - 12:02 PM
Does the info sheet tell you what voltage the wideband controller outputs at 10AFR/0.68lambda and 20AFR/1.36lambda as that's what OBDTuner will need to know. ETA: Looking at the graphs on the PLX site, the settings are the same as before regarding voltage. Linear output at 0v for 10AFR and 5v for 20AFR. http://www.plxdevice...?id=SEMOSMAFRV4
Edited by techieboy, 08 April 2015 - 12:05 PM.
#1391 CHILL Gone DUTCH
Posted 08 April 2015 - 12:26 PM
Change it at bottom of this screen nick
(settings )
#1392 NickB787
NickB787
  • 7,813 posts
Posted 08 April 2015 - 01:04 PM
Your right Matt the box said Gen 4 PLX ( A white sticker) with LSU4.9 but all the paperwork is for a gen3 unit, not a happy bunny just got off the phone, its a mistake from the USA send unit back....... Just put the undertrays back on AHHHH
#1393 NickB787
NickB787
  • 7,813 posts
Posted 20 April 2015 - 03:11 PM
looks like it's sorted I have a lsu 4.9 sensor so just need to try it, will try your setting Chill, what effect does this have on reading?
#1394 CHILL Gone DUTCH
Posted 20 April 2015 - 03:33 PM
As long as the voltage matches the output (AFR) it shouldn't have any effect Can you download the setting for the sensor you have You also need to have the sensor delay time
#1395 CHILL Gone DUTCH
Posted 20 April 2015 - 03:39 PM
Which sensor did you get in the end nick
Edited by CHILL Gone DUTCH, 20 April 2015 - 03:40 PM.
#1396 NickB787
NickB787
  • 7,813 posts
Posted 20 April 2015 - 03:53 PM
to cut a long story short PLX have been running the Bosch LSU 4.9 since their gen 3 went out but for some reason they still called them LSU 4.2 units they were however bosch 4.9 units I went and checked the Bosch s/n's. I had a gen 2 which was a LSU 4.2 so my setting will be incorrect for the 4.9.
Edited by NickB777, 20 April 2015 - 03:55 PM.
#1397 CHILL Gone DUTCH
Posted 20 April 2015 - 03:56 PM
are the right settings available
#1398 techieboy
Posted 20 April 2015 - 03:57 PM
Yes, the voltages vs AFR settings are as they were originally. Just the sensor response time that is unknown.
#1399 NickB787
NickB787
  • 7,813 posts
Posted 20 April 2015 - 03:58 PM
from the PLX     http://www.plxdevice...?id=SEMOSMAFRV4 Physical Dimensions: 2 x 2.875 x 1.125" (52 x 75 x 28mm) L x W x H Technology: PLX Critical Response Technology, Fast Response PID Accuracy: < 0.1AFR (Gasoline) Wideband, < 0.2AFR (Gasoline) Narrowband Measurement Range: 10-20 AFR (Gasoline) 0.68 - 1.36 lambda (Gasoline) 0 - 100 O2 Sensor Health 0 - 1000 mS Reaction Time 9 - 20 Volts Analog Outputs: Wideband Linear 0-5V, Narrowband 0-1V (Driving Current 20mA) Operating Voltage: 9V-20V Power Consumption: 20 Watts (Max), 13 Watts (Typical) Power Supply Technology: High Efficiency Switching with Soft Start Technology Operating Temperature: 0 - 85 Deg Celsius Sensor: One Bosch LSU 4.9 Enclosure: Extruded Aluminum
#1400 NickB787
NickB787
  • 7,813 posts
Posted 20 April 2015 - 04:07 PM
Found this http://www.ecotrons....9_Tech_Info.pdf
