Ecu Change
#1401
Posted 20 April 2015 - 04:11 PM
#1402
Posted 20 April 2015 - 04:15 PM
#1403
#1404
Posted 20 April 2015 - 04:16 PM
Not sure that matters, the voltages output for any given AFR and the response times are a function of the particular controller you use. Maybe PLX can tell you what the response time is (delay between what it reads and what it outputs, I assume) but I'd start at 100ms. If the logging is fast enough, you should be able to fine tune it even without anything from PLX.Found this http://www.ecotrons....9_Tech_Info.pdf
#1405
Posted 20 April 2015 - 05:08 PM
Asked Peter what is Best awaiting his reply
#1406
Posted 20 April 2015 - 05:38 PM
Edited by NickB777, 20 April 2015 - 05:45 PM.
#1407
Posted 20 April 2015 - 06:38 PM
A gauge wouldn't solve anything and would just give you a chav fest inside the cabin. You've got the important piece of info, the controller output voltage to AFR mapping. So you'll know how the engine is fuelling at any given moment, which is what you want to know. You might just have a delay of a few thousandths of a second between what the lambda sensor reads and the controller sends and what number the engine ECU receives. You'd still have that delay with a nasty gauge and unless the delay was measured in whole seconds, you'd likely never be able to see any lag anyway.Thanks Guys I should have got a gauge..
#1408
Posted 21 April 2015 - 08:06 AM
There's also a delay coming from you sensor position in the exhaust pipe.
Just fit the thing and start tuning.
#1409
Posted 22 April 2015 - 02:43 PM
#1410
Posted 22 April 2015 - 03:17 PM
#1411
Posted 22 April 2015 - 03:18 PM
#1412
Posted 22 April 2015 - 03:38 PM
Edited by NickB777, 22 April 2015 - 03:39 PM.
#1413
Posted 22 April 2015 - 03:46 PM
#1414
#1415
Posted 22 April 2015 - 03:47 PM
#1416
Posted 22 April 2015 - 04:16 PM
Edited by NickB777, 22 April 2015 - 04:17 PM.
#1417
Posted 22 April 2015 - 04:22 PM
#1418
Posted 22 April 2015 - 04:24 PM
Have you tried it without gasket since the software update ?I don't don't get that. I had the original problem which was solved by the updating to the latest software release. I am running a 3.0 Bar map sensor for info did you use a gasket, I made one up when I thought my problem might have been air leaking
#1419
Posted 22 April 2015 - 04:34 PM
Edited by NickB777, 22 April 2015 - 04:34 PM.
#1420
Posted 22 April 2015 - 04:35 PM
😆😆😆😆 Any particular brand lolno I couldn't be bothered removing the TB Cheap mod but used a bit of cardboard from a Kellogg's box
