The manifold is not designed for these power levels Hence the big temps most experience on track So we will always be restricted by the manifold its more how much can we cover up The manifold prolly would be better with a good portingHow will it be when water injection will be keeping it cool and doing its job that the manifold will be running better then when it was running standard bhp it was designed for 😀That poor lsj manifold is going to get more abuse then a seventies Jim'll Fix It audience.
Ecu Change
#1481
Posted 05 June 2016 - 01:28 PM
#1482
Posted 05 June 2016 - 02:07 PM
Well, if nothing else, we at least proved your fuel system held pressure.
#1483
Posted 05 June 2016 - 07:54 PM
#1484
Posted 06 June 2016 - 03:50 PM
Edited by NickB787, 06 June 2016 - 03:57 PM.
#1485
Posted 06 June 2016 - 03:52 PM
matt dont no if your tablet connects to the internet but when i did a update, i had to re-install the driver to the tablet,
#1486
Posted 06 June 2016 - 03:59 PM
Yeah, updated to a whole new version of Windows 10 last night but it should be fine as I tested an ECU read with it on my car just before I went down to Nick's.
#1487
is your car running badly nick
#1488
Posted 06 June 2016 - 04:16 PM
Edited by NickB787, 06 June 2016 - 04:17 PM.
#1489
Posted 06 June 2016 - 04:19 PM
send it away
are you expecting it to be the ecu
#1490
Posted 06 June 2016 - 04:20 PM
Most put it behind the air intake pipe, for easy access/removal.
Where on earth did you put it?
Edited by smiley, 06 June 2016 - 04:24 PM.
#1491
Posted 06 June 2016 - 05:03 PM
#1492
Posted 06 June 2016 - 09:28 PM
We know my tablet and interface works on my car and OBDTuner also reported that it was successfully "connected" to your car, but we're assuming that my copy of OBDTuner with my serial/key/registration number can read your ECU which might only work with it's own serial number.......
#1493
Posted 06 June 2016 - 09:36 PM
#1494
Posted 06 June 2016 - 09:37 PM
#1495
Posted 06 June 2016 - 09:59 PM
It won't read nicks with your key Unless I've read your comment wrong
Nope, you're reading it right. Hold off on the OBD port butchery Nick......
#1496
Posted 06 June 2016 - 10:48 PM
#1497
Posted 07 June 2016 - 08:08 AM
Edited by NickB787, 07 June 2016 - 08:09 AM.
#1498
Posted 07 June 2016 - 12:32 PM
7 user(s) are reading this topic
0 members, 7 guests, 0 anonymous users
