Light Switches Mod
#21
Posted 09 May 2011 - 09:05 PM
#22
Posted 09 May 2011 - 09:34 PM
#23
Posted 15 May 2011 - 01:17 PM
oops forgot
can you wait till the weekend?
Bump in preperation for Slindborgs guide...
#26
Posted 05 June 2011 - 08:54 PM
Edited by slindborg, 05 June 2011 - 08:54 PM.
#28
Posted 05 June 2011 - 10:00 PM
tasty switches...
Do they latch internally given they only have a pair of connectors and no relays etc?
The pin blocks are not plugged on the backs in my other photos. They are basically a two in one push to make eah side, like this -
#29
Posted 07 June 2011 - 06:36 AM
#30
Posted 07 June 2011 - 09:15 AM
#31
Posted 07 June 2011 - 11:01 AM
#32
Posted 11 November 2011 - 02:47 PM
#33
Posted 11 November 2011 - 03:14 PM
just on the hunt for switch wiring, as one of my switches has gone still and two others no longer have lights on them.
all i want to do is bung some toggle switches in there. is this a tricky job or am i over thinking it?
Very easy (I did it
#34
Posted 11 November 2011 - 03:20 PM
#35
Youll probably want to make a few of the wires redundant and tap them off as toggle switches may not utilise the conditional wires and 2 stage illumination.
I noticed this on ebay earlier actually. Bit pricy for what it is but might be a handy ready made starting point for you to tidy up a bit?
Edited by -Dab-of-Oppo-, 11 November 2011 - 03:21 PM.
#36
Posted 11 November 2011 - 03:34 PM
Edited by davemate, 11 November 2011 - 03:35 PM.
#37
Posted 11 November 2011 - 03:49 PM
#38
Posted 11 November 2011 - 03:56 PM
I know where all 7 wires are all going doing but how to adapt them to a 3 terminal switch is confusing me.
You can't, you need at least a 6 pin switch with 2 normally closed legs any other configuration would have wires bridging which will mean you would have to indicate at the same time as pressing the switch to have both sides flashing together. If you do away with the back light and main illumination you could drop it to 5 terminals.
I'll PM you both in a bit.
#39
Posted 11 November 2011 - 04:39 PM
Edited by slindborg, 11 November 2011 - 04:39 PM.
#40
Posted 11 November 2011 - 09:55 PM
Regards, Paul
