Edited by Nev, 11 October 2011 - 07:16 PM.
Posted 11 October 2011 - 07:03 PM
Posted 11 October 2011 - 07:19 PM
Let me know if you want a big power ZLEx engine, am keen to start another project...
If you are putting fat wheels on you might be able to plant 500 ft/lb down on the tarmac.It would be fun to get 500 ft/lb out of 2 Litres at 8500 revs.... works out at approx 760 BHP.... EPIC !
BTW, where abouts in the country are you based please ?
EDIT: Oh crap, just looked at the pics again and can see an NA exhaust pipe - please dont tell me its an NA ?!
Posted 11 October 2011 - 07:20 PM
Posted 11 October 2011 - 07:26 PM
What engine is he thinking of ?
Posted 11 October 2011 - 07:50 PM
Thanks for the offer nevWhat engine is he thinking of ?
Edited by atom x, 11 October 2011 - 08:05 PM.
Posted 11 October 2011 - 08:40 PM
Posted 11 October 2011 - 08:50 PM
Posted 11 October 2011 - 08:56 PM
stroke is 78mm
mean piston speed will not exceed 25m/s
work it out slindy
Posted 11 October 2011 - 09:00 PM
9615rpm?
Posted 11 October 2011 - 09:02 PM
Posted 11 October 2011 - 09:05 PM
Posted 11 October 2011 - 09:09 PM
Posted 13 October 2011 - 01:48 PM
Edited by Nev, 13 October 2011 - 01:53 PM.
Posted 13 October 2011 - 01:53 PM
Posted 13 October 2011 - 02:07 PM
Am looking forward to seeing what power and torque this little rev monster can make without a turbo.
Are you keeeping the B207 con rods presumably?
Will you raise the SCR with a thinner HG ?
Posted 13 October 2011 - 02:10 PM
there is an alternative way to make more bangs per minute , and have a silly short 74.8mm stroke, 89mm bore and a much better noise Z2?NET
Posted 13 October 2011 - 02:41 PM
I dont understand please explain (I hope you don't lecture english)
Posted 13 October 2011 - 02:44 PM
Edited by Nev, 13 October 2011 - 02:47 PM.
Posted 13 October 2011 - 03:34 PM
As I'm sure you know, it's always risky/scarey doing all your own proto-typing. I hope it all works out.
What sort of power are you expecting? What ECU?
If you've offset ground the crank rod journals doesn't that make your bigs ends rather weak due to the reduction of material?
