Here's why I did it. Found this before the national last year and it made me think about selling up. Big thanks to Garry for swaying me towards S2K but the missus refused to let me sell it.
Decided to strip and rebuild just to make sure it was right. Took it off and broke it down. Not easy! I ended up with a broken finger when a troublesome ball joint finally gave and sent heavy bits of metal flying. Here's the scabby bits:
Got it blasted:
Plated the small bits myself with a gateros plating kit but you cant make enough electrolyte to do the big bits with one lot of chemicals so got the big bits done by brinksway. Their service is terrible, dont use them!!
Plated bits:
Retapped all the threads. Decided to coat it in one of those underbody rubber coatings (not the tar one, the rubber one). I used U-pol's finest and that is also rubbish!
Mmmmm, shiney!
This is the bit you dont want to hear....
Blasting 40 quid
plating 120 quid from rip-off brinksway bah!
Upol coating 15 quid
Cliffie bushes 160 I think
Set of ball joints 40 quid
Lotus TRE's 50 quid
Lotus Drop links 50 quid
Lotus sport adjustable arb 90
roll bar bushes 30
toe links 80 each
New set of bolts 35
HCB's 15
Think thats about it. I did consider the possibility of elise parts wishbones as they have bushes and ball joints. Might be an alternative to a refresh.
Edited by FLD, 27 April 2011 - 05:09 PM.
