Reverse Lights
Posted 10 May 2011 - 02:09 PM
Posted 10 May 2011 - 02:11 PM
Posted 10 May 2011 - 02:13 PM
Edited by Craig S, 10 May 2011 - 02:14 PM.
Posted 10 May 2011 - 02:18 PM
Posted 10 May 2011 - 02:30 PM
Posted 10 May 2011 - 02:34 PM
Posted 10 May 2011 - 02:41 PM
Clear lens which I think is on the right.
Fog on the left (red lens).
Cheers Pal very grateful!
Posted 10 May 2011 - 02:43 PM
I would go for the order:
1. Check the bulb
2. Check the connection (follow the cable as a connector can work loose it dangles round about the engine cut off switch)
3. Check the switch on the gear box
Snap with size 10
this link helped my diagnose mine was the swtich but it just needed the connectors cleaning and it was all good
Posted 10 May 2011 - 02:45 PM
Correction... (assuming we are talking about a RHD VX)
The reversing light is on the left. The passenger side.
Posted 10 May 2011 - 03:39 PM
50:50 and got it wrong.
Guest_Minno (Guest)
Posted 11 May 2011 - 08:30 AM
Posted 11 May 2011 - 08:33 AM
I had the same problem last week. Took the switch out, sprayed with WD40 plunged the plunger a few times, refitted and it's worked ever since!
Well its not the bulb as that was changed and checked last night. The wiring is looking perfect...most prob the sensor
CT
Posted 11 May 2011 - 10:54 AM
CT
Where is best place to get one? Good old Halfrauds? Checked on ebay but could not see one?
What is the actual part called? Simply "reverse light sensor"?
Thanks for yoru help boys and girls
Christian
Posted 11 May 2011 - 10:59 AM
Posted 11 May 2011 - 11:56 AM
CT
Christian
Seriously.... Before changing the switch unplug the wire from it and spray the connectors with WD40 and refit.... Worked on mine. Saves the hassle and expense if it isn't really needed.
Posted 11 May 2011 - 12:46 PM
Posted 06 December 2015 - 04:34 PM
Posted 06 December 2015 - 08:05 PM
