Engine Oil
138 replies to this topic
#41 fezzasus
Posted 09 January 2013 - 10:55 AM
Probably to reduce the risk of losing oil pressure when cornering.
shouldn't be a problem in a dry sump system.
#42 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 09 January 2013 - 11:23 AM
There is that haha. Extra cooling capacity then.
#43 Bargi
Bargi
  • 4,483 posts
Posted 09 January 2013 - 12:30 PM
FYI. For anyone who predominately tracks their car, this oils is very good and a seriously good price: http://www.opieoils....chTerm=oldlabel
For £20 for 2 litres doesn't seem that good, is the oil that much better than say Fuchs Titan Race Pro S 10W-50 @ £40 for 5 liters?
Edited by Bargi, 09 January 2013 - 12:30 PM.
#44 siztenboots
  • 26,613 posts
Posted 09 January 2013 - 12:36 PM
the Pro S is ACEA A3, B3
#45 fezzasus
Posted 09 January 2013 - 12:55 PM
Much better, As pointed out, it's ACEA A3/B3 which means wear or piston deposit performance is poor, I wouldn't really classify it as a high performance oil - the high performance oils tend to resort to marketing rather than proof of performance to sell oil. I've personally been part of the development of the Motul oil and compared it to a massive range of competitors, it's significantly better than the majority in terms of anti-wear performance and friction reduction. It will help your engine and should result in an increase in bhp vs. a standard oil, however it's a relatively small gain (3 or 4 % at a guess)
#46 JG
JG
  • 13,612 posts
Posted 09 January 2013 - 12:57 PM
no 10w50 though
#47 Bargi
Bargi
  • 4,483 posts
Posted 09 January 2013 - 01:29 PM
Is the 15W OK enough for everyday driving? (not daily driver)
#48 siztenboots
  • 26,613 posts
Posted 09 January 2013 - 01:30 PM
isn't the 15w more of a summer oil
#49 Winstar
Winstar
  • 4,264 posts
Posted 09 January 2013 - 01:37 PM
no 10w50 though
at the temperatures your car will see a 15w wouldn't be much different to a 10w
I've been trying to find the cuves but a 15w at the type of temperatures most of us would consider using a VX won't be thicker than a 10w at min temperature (usually about -20'C)
#50 hughcam
hughcam
  • 730 posts
  • Interests:driving, motorcycling, snowboarding, v12 lawn mowers
Posted 09 January 2013 - 01:50 PM
I would say 3-4% is a massive gain on even a standard engine lol. Cheaper than buying exhaust and induction kits that probably provide around the same increase.
#51 fezzasus
Posted 09 January 2013 - 03:09 PM
no 10w50 though
Not exactly.
Temperature curves are dependent on the viscosity index (VI) of the oil, this differs depending on the base stock, thick additives and viscosity modifiers. Poor quality base stocks have low VI, high quality have high VI. viscosity modifiers have different VI depending on the application they are designed for.
For two oils with identical component slates (meaning they use components of the same quality at the same treat), a 20W-40 oil will have a lower total VI than a 0W-60, meaning the former will have a much lower gradient than the latter, the result of that is there is always a difference (although could potentially converge) in viscosities at a given temperature.
#52 fezzasus
Posted 09 January 2013 - 03:11 PM
0W flows at -40 C
5W flows at -35
10W flows at -30
15W flows at -25
20W flows at -20
all will work in the winter, however for a daily driver where you just get into it and go in the winter i'd be happier with something thinner.
#53 fezzasus
Posted 09 January 2013 - 03:12 PM
should be fine, fuel economy might drop a bit if you do lots of short distances.
#54 siztenboots
  • 26,613 posts
Posted 09 January 2013 - 03:13 PM
no good for chips then
#55 fezzasus
Posted 09 January 2013 - 03:17 PM
baby oil is just mineral oil and a scent, if it's good enough for babies it's good enough for chips.
#56 Steelic
Steelic
  • 544 posts
Posted 09 January 2013 - 09:13 PM
Fuchs supersyn 5w/40 5L is £21 from AGMpartscomponents behind Morrisons in Spalding. Delivery extra.
#57 fezzasus
Posted 10 January 2013 - 01:36 PM
no 10w50 though
Knocked this up quickly, if anyone wants oil specific values let me know. They are all linear relationships and can be extrapolated as such (other than at less than 5 cSt). Notice how the monograde has a much steeper gradient, this is due to the lower VI.
#58 Winstar
Winstar
  • 4,264 posts
Posted 10 January 2013 - 05:02 PM
no 10w50 though
Not exactly.
Interesting I thought they had to conform to a certain SAE curve as the first job I did when I joined Lotus was program them all into the Flowmaster materials database, may be they where just some test sample then.
#59 fezzasus
Posted 10 January 2013 - 05:15 PM
no 10w50 though
Not exactly.
All viscosities can be modelled using A-BlogT = log log(v+0.7) where A and B are experimentally identified constants - it's how I created the graph above, because this produces a linear graph you can simply go off two experimentally measured kinematic viscosities (usually 100 and 40), but there's no need to conform to any SAE specification - only one KV at 100 C measurement is part of the specification and that identifies a working range for each SAE grade, the other measurement are high temperature high shear and cold cranking simulator which measure different attributes, the net result is an SAE grade is determined by three points on three different graphs, so there's nothing following a set curve.
EDIT: SAE grades are available on the last page of this: http://www.infineum....ations 2010.pdf
Edited by fezzasus, 10 January 2013 - 05:18 PM.
#60 Type 116
Type 116
  • 45 posts
  • Interests:Cars and Boxer dogs. Land Rovers, green laning, most of all, drinking tea.
Posted 26 February 2013 - 11:12 PM
That is the best explanation I have ever read regards what all the acronyms mean on me tub of oil! Now I just need some wynns oil treacle a the jobs a gooden!
