Front Splitter New
  • This topic is locked This topic is locked
305 replies to this topic
#81 FLD
Posted 07 October 2011 - 07:00 PM
Looks like I'll be busy then. Been asked for a few sets.
#82 MAXR
MAXR
  • 2,719 posts
Posted 07 October 2011 - 07:59 PM
...hope I'm first on the list! Sod Joe! chinky chinky
#83 FLD
Posted 07 October 2011 - 08:24 PM
Yeah, you're the guineapig!
#84 GeorgeBC
GeorgeBC
    Needs a cheaper hobby
  • 3,138 posts
Posted 08 October 2011 - 02:37 AM
Prob pissing in the wind but would it be poss to make some blanks to fit where the headlamps go??
I'm in the process of this one. Keep badgering me, I have a memory like a seive.
A special resin (vinylester) and barrier (PTFE film) is required for the mould or you scrap a pair of lamps!!! Polyester will attack the lenses so you cant use wax or pva and regular glass.
Pm darron as im sure his headlights are fubared anyway. thumbsup
#85 robin
robin
  • 3,810 posts
Posted 08 October 2011 - 07:40 AM
Back on track now one set of splitter and louvers available for imediate dilivery. £240 dilivered
#86 FLD
Posted 08 October 2011 - 08:48 AM
Aye, sorry about the little hijack. £240 is cheap, I know how much work these are to produce and wouldn't do it at that price.
#87 robin
robin
  • 3,810 posts
Posted 13 October 2011 - 08:35 PM
should of put also splitter available on own still for £180 diliverd. available now.
#88 darronwall
darronwall
  • 2,706 posts
Posted 22 October 2011 - 02:26 PM
do you have a splitter ready???
#89 robin
robin
  • 3,810 posts
Posted 22 October 2011 - 06:25 PM
can have one next week if you like
#90 darronwall
darronwall
  • 2,706 posts
Posted 23 October 2011 - 10:11 AM
pm me your details ect cheers darron
#91 robin
robin
  • 3,810 posts
Posted 30 October 2011 - 10:20 PM
have another ready to go if anyone intrested.
#92 darronwall
darronwall
  • 2,706 posts
Posted 30 October 2011 - 10:39 PM
got mine and all is good!
#93 jameso
jameso
  • 2,336 posts
Posted 30 October 2011 - 11:15 PM
Fitting guide please darren :P
#94 robin
robin
  • 3,810 posts
Posted 31 October 2011 - 06:58 AM
Ill be doing a fitting guide this week
#95 jameso
jameso
  • 2,336 posts
Posted 31 October 2011 - 08:10 AM
great thanks :)
#96 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 31 October 2011 - 10:19 AM
Good I will try to fit mine then thumbsup
#97 jameso
jameso
  • 2,336 posts
Posted 10 November 2011 - 09:08 AM
Did you get round to that guide Robin?
#98 robin
robin
  • 3,810 posts
Posted 10 November 2011 - 04:31 PM
Sorry not yet been very busy so not even looked at it will be on it asap
#99 robin
robin
  • 3,810 posts
Posted 13 November 2011 - 05:23 PM
fitting guide
Had time to do a quick fitting guide so hope this helps
tools required. Drill,drill bit (8mm depending on fittings) bolts and washers, sockets and spanners and a paerson to help if you have one available.
Firstly i made a small ramp using scafolding planks but other items can be used to give you clearance to be able to drill holes.
Then remove bolts that hold the underside of the front clam to aid access later on and bolts that hold the wheel arch liners on in front of wheels
Then place splitter up to car to check fitment (i used a barrel and some overalls to hold in place as didnt have spare hand)
#100 robin
robin
  • 3,810 posts
Posted 13 November 2011 - 05:30 PM
next is to drill first hole i drilled the first hole through splitter and clam in one go to keep alignment.
then tightened this so most was just about tightened but still alowed movement in splitter.
this is done by reaching through the wheel arch liner so you can hold nut to tighten
then do same on other side.
then check alignment again to make sure all looks good bofore drilling other holes i did three aditional holes for fixings but you can do four if you like.
to fit bolts i reached through the gap between the underside of car and the clam was easy enough to reach each fitting
