Engine Cover (Exige Style)
303 replies to this topic
#121 JG
JG
  • 13,612 posts
Posted 03 January 2012 - 10:17 PM
yep, it would almost go in the same sentence as the word 'chav'. The TMS car looks far more purposeful yet retains the standard car's sillouette.
#122 Baron Von Scubadaddy
  • 6,644 posts
Posted 03 January 2012 - 10:19 PM
What the R3 ? please you are having a laugh
#123 Baron Von Scubadaddy
  • 6,644 posts
Posted 03 January 2012 - 10:20 PM
:sick:
#124 Baron Von Scubadaddy
  • 6,644 posts
Posted 03 January 2012 - 10:25 PM
oh please rallly :grouphug:
#125 MrSimba
MrSimba
  • 5,197 posts
Posted 03 January 2012 - 10:29 PM
It looks like it's just fallen out of the 'Ripspeed' catalogue in Halfords! :o
#126 Baron Von Scubadaddy
  • 6,644 posts
Posted 03 January 2012 - 10:37 PM
I think thats it !
It looks like a jelly mould
I was more about this angle
This a topic about an engine cover
not a front splitter
or an apple fritter
#127 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 03 January 2012 - 10:47 PM
Yup James, off that very car.
Its a one off isn't it?
I'm guessing the mould no longer exists anyway
No, I have a spare carbon roof and a fibreglass roof to sell at some point and the moulds are intact and available.
#128 rallyka
rallyka
  • 47 posts
Posted 03 January 2012 - 10:50 PM
Will a roof from an exige fit a vx220? looking at the race roofs on ebay, just wondered?
#129 techieboy
Posted 03 January 2012 - 10:53 PM
No. Not without so much modification that you might as well make one from scratch to fit properly, in the first place.
#130 rallyka
rallyka
  • 47 posts
Posted 03 January 2012 - 10:56 PM
Thanks Techie, Cliffie do you want to sell the fibreglass roof?
#131 Winstar
Winstar
  • 4,264 posts
Posted 03 January 2012 - 10:57 PM
My kit is not for you Neil, it is really for race cars that are looking to reduce drag.
EFA, also I suspect it really need the rear calm cutting to maintain cooling airflow through the engine bay
TBH it needs to be a solution that allows easy access to the boot/engine
#132 Baron Von Scubadaddy
  • 6,644 posts
Posted 03 January 2012 - 11:11 PM
So would cliffies need more vents in the clam to be more effective ? Also would directing air into the engine bay via the roof scoop have an effect on cooling could you re direct the air across the rear diffuser and win the F1 ?
#133 FLD
Posted 04 January 2012 - 10:50 AM
Any more pictures from rear cliffie
Looking at that picture its very square cut. Looks like a piece of tooling board cut to shape, louvres added and then another piece stuck on for the scoop. Wouldn't be too hard to copy (almost exactly) if someone had the time.
#134 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 04 January 2012 - 12:49 PM
Book some time off work then chap.
#135 FLD
Posted 04 January 2012 - 12:52 PM
If you saw my 'projects' list you'd think I needed a year off!
#136 Winstar
Winstar
  • 4,264 posts
Posted 04 January 2012 - 01:36 PM
It depends the air flow through the engine bay on the VX enters through the ears and the NACA ducts then exits mainly via the grills on the engine cover. Therefore if you want to maintain this then you need to make sure the vents are big enough. However if you have a roof scoop that's not feeding sealed air box or ducted down to the engine then you could just end up with the air short circuiting and going stirght out the vents and not cooling the engine bay. To get the air flow through from the roof scoop to cool the engine bay you need to remove the boot and cut the rear clam. The only real use the small vents in the calm will be are when the car is stationary to allowing heat to convect out.
Not but you could move the exhaust up and fit a double diffuser ;)
Same here possibly 2
#137 Baron Von Scubadaddy
  • 6,644 posts
Posted 04 January 2012 - 06:01 PM
See I knew you knew what you were talking about. So is it better use the scoop to feed my air filter and leave the lid solid with vents of the same size as the boot lid ones or at least use the same amount cm2 of grill Imnotworthy
#138 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 05 January 2012 - 02:21 PM
not that i can afford either or would actually fit either, i have to say the first red one on page 1 looks nicer then cliffies but thats just IMO :lol:
#139 Kev S
Kev S
  • 608 posts
Posted 05 January 2012 - 05:57 PM
:yeahthat:
I'd like my car to look like the black one, although it's silver :groupjump:
I'd be interested if we cold have that look thumbsup
#140 jakbvx
jakbvx
  • 704 posts
Posted 05 January 2012 - 06:42 PM
I'd also have one of these, I prefer the louvres that are the whole width of the back rather than cliffies version with 1 set each side. Both look :wub: though. Why didn't I have mine done matt black instead of snot green......... That one is perfection!
    Bing (1)
