N/a + Eaton M62 Supercharger = 300 Bhp Target
43 replies to this topic
#21 The Batman
Posted 04 June 2011 - 03:45 PM
True the valves and springs aren't needed but my last one was revving to 7200 and too be honest it's a security thing you spend all the money on the bottom end you wouldnt want to damage it with standard parts! Feel free to go for it though :lol: Mmm 2" primaries shame I covered them up :( If I was you and making an exhaust I would buy a piper manifold as it has a 3" exit bore then make a downpipe and backbox thumbsup Defo do the balance delete Also I would change the clutch and flywheel the clutch I doubt can handle it... But again it's one of those things it might... But the engine is out etc etc chinky chinky
#22 maybach
maybach
  • 63 posts
Posted 04 June 2011 - 03:59 PM
Don't forget all the suspension and other upgrades you will need with 300bhp those corners become oh so tight ;)
#23 greasemonkey
greasemonkey
  • 485 posts
  • Interests:trackdays, golf, fishing, skiing, cycling and 10k runs
Posted 04 June 2011 - 05:44 PM
Has anyone fitted a new standard clutch on a SC car and found it to slip? i dont mean an old original one a new one that could not cope with the extra power, im just not wanting to change the feel of the car to much, bitting point of the cluch etc. Can anyone say from experiance? I am having a goaning noise from the cluch from cold and have had a burning smell after a trafic light grand prix. so it on my list to change, but i know the cast of the uprated ones! Does deleting the balancer shafts and fitting a lightened flywheel gain that many more horses? FLD has offered to do it for me as he did or has seen it done on his, and its near a free mod as i understand, but still need more convincing before i disturb the engine internals that much. Is the flywheel dual mass? might change it to lightened if that is the case, from experiance they are S**t. Ive got turbo suspension fitted so its already firmer than standard suspension and have mintex 1144 pads fitted. I know there is far better suspension packages around and better pads/discs, but they can be changed at a later date if i feel the car needs it. People might think im :beat: crazy doing it this way round but the car will only go as fast as you allow it to. thumbsup Can see the gain from fitting the valve springs and lightly porting the head but larger valves? im not sure. Joe or anyone else have you fitted larger valves with the bigger BHP cars? how much are the sodium filled saab valves?
#24 The Batman
Posted 04 June 2011 - 05:50 PM
All 300bhp vxs apart from techies have large valves and duel springs The uprated Cms clutch is very similar to the standard clutch in terms of feel just can handle the uped torque :) The flywheel isnt duel mass The balance delete will make it vibrate more on idle as the blower cams do and poly bushes butiabt unbearable unless you have a rattle :lol:
#25 greasemonkey
greasemonkey
  • 485 posts
Posted 04 June 2011 - 06:04 PM
Ok then joe chinky chinky what size valves are people using? Who are CMS? Is there anyone still running with the balance shafts in a SC car?
#26 luke.
luke.
  • 2,167 posts
Posted 04 June 2011 - 06:17 PM
Who are CMS?
Courtenay Motorsport unless i am mistaken
#27 Seb.F
Seb.F
    Under Your Bed
  • 6,045 posts
  • Interests:Tech head
Posted 04 June 2011 - 06:24 PM
Who are CMS?
My one was stage 2 and ran with balance shafts.
#28 The Batman
Posted 04 June 2011 - 06:38 PM
All stage 2 pretty much will as it's not viable taking the engine out to do the balance delete! Jimmy has deleted them tho Majority run the fm racing valves 0.5nm bigger
Edited by joe_589, 04 June 2011 - 06:38 PM.
#29 greasemonkey
greasemonkey
  • 485 posts
Posted 04 June 2011 - 06:45 PM
Who are CMS?
:beat: :lol:
#30 allsteel
allsteel
  • 445 posts
  • Interests:Winning lottery tickets,scantily clad women,real ale poured with a head,modified cars,great guitar playing.
Posted 04 June 2011 - 08:35 PM
Don't forget the mapping also. There is a standardish map for 250 brake but will need re-doing for 300.
#31 The Batman
Posted 04 June 2011 - 08:42 PM
The mapping is exactly the same as remapping a stage 2 :rolleyes:
#32 Phear
Phear
  • 1,125 posts
Posted 04 June 2011 - 11:33 PM
I'm running standard clutch on Stage 2 with no problems at all, will let you know if it handles Stage 3 in a few weeks, however I can't see there being an issue. Torque kills clutches, not bhp.
#33 greasemonkey
greasemonkey
  • 485 posts
Posted 04 June 2011 - 11:38 PM
chinky chinky
#34 maybach
maybach
  • 63 posts
Posted 05 June 2011 - 11:48 AM
hi mine is a standard clutch the original of unknown mileage , all ok so far :mellow: . An uprated clutch i looked into only rated to about 270bhp so i didnt think the risk of cost and driveability was worth bothering with at this stage. I drive alot of cars with competition clutch's believe me the novelty soon wears off in traffic.
#35 davemate
davemate
    Harrop!!!
  • 3,228 posts
  • Interests:Provoking Badgers
Posted 07 June 2011 - 09:48 PM
Maybe a Saab head is worth considering? Mine is stage 2, happy with it for now. The flywheel just means the car has less weight to lug, it won't change bhp figures but it will change the feel of the engine. Ttv did mine Rads, cams, fuel pump can all be bought from cliffie.
#36 greasemonkey
greasemonkey
  • 485 posts
Posted 11 June 2011 - 11:01 PM
Started to order some bits from cs :groupjump: Idle Pulley, Bracket and Bolt 2.2 S/C SCIPBB 1 £65.08 Bolts - Alternator Bolts and Washers 2.2 S/C (Set of 2) ABSC 1 £1.25 Gasket - Inlet Manifold to Supercharger 2.0 2.2 Z22SE IMSCG 1 £28.88 Inlet Manifold Support Bracket S/C IMSBSC 1 £35.79 Map Sensor 2.2 S/C Stage 1 and 2 MSSC12 1 £53.00
#37 smiley
Posted 12 June 2011 - 12:14 PM
Ah, the one with the bolt from hell :lol:
Good luck with it thumbsup
#38 Anarchy
Anarchy
  • 2,237 posts
Posted 20 June 2011 - 09:58 AM
These are just rough prices inc shipping and vat just to make a start, will be shoppping around a bit more yet, any pointers of things ill need or have missed or even links etc very welcome ! :D
Pistons and rods £645.00 My link
Pulley system £70.00 My link
VXR Injectors (listing ended just an example) £80-100 My link
Cams £410.00 My link
Valve springs £363.00 My link
Rebore £100-120
The pulley system you list, is the main purpose of this to allow a quicker pulley swap over with the SC in place as and when you upgrade?
#39 greasemonkey
greasemonkey
  • 485 posts
Posted 04 July 2011 - 10:57 PM
Ive not updating recently as ive had a death in the family and been to glastonbury more recently. But finally trying to get back on track and get some parts ordered before my fiancee spends all the money in my account. :beat: Got some questions for you guys What is the part number for the corsa top hose required?
#40 Bargi
Bargi
  • 4,483 posts
Posted 05 July 2011 - 05:07 AM
<br />Ive not updating recently as ive had a death in the family and been to glastonbury more recently. But finally trying to get back on track and get some parts ordered before my fiancee spends all the money in my account.  <img src='http://www.vx220.org...802beat_prv.gif' class='bbc_emoticon' alt=':beat:' />  <br /><br />Got some questions for you guys<br /><br />What is the part number for the corsa top hose required?<br />
<br /><br /><br />
GM90444470
http://www.courtenay...r/prod_807.html
Might want to check with Joe about using a different hose if possible. The pipe on mine was hitting the SC pulley which cut it open. Fix is to cable tie it to the fuel lines which isn't ideal.
