Front Roof Seal
36 replies to this topic
#21 Bardolphs
Bardolphs
  • 45 posts
Posted 28 August 2011 - 03:11 PM
Can the drain cups be bought individually to fit the original ? Or are they only part of a full replacement window seal ?
#22 JG
JG
  • 13,612 posts
Posted 28 August 2011 - 03:15 PM
full replacement.
#23 techieboy
Posted 28 August 2011 - 03:35 PM
If all you're bothered about is the "cups" and your existing seal is in decent condition, I wouldn't bother replacing. They're by no means a 100% fix for any leaks and you'd be much better off making sure the windows and roof seal properly.
#24 Bardolphs
Bardolphs
  • 45 posts
Posted 28 August 2011 - 04:27 PM
Cheers. Thanks for the info.
#25 TazN
TazN
  • 2,931 posts
Posted 29 August 2011 - 07:03 PM
Well managed to get the seal off, cleaned up and new one fitted in about 3-4 hours. It wasn't fully water tight so used some silicon sealant. Has passed the watering can test, now just need to wait and see if it can withstand a English downpour. Had problems with the sticky pads on the back not sticking down the sides. So had to stick it down some sealant. All in all not a hard job at all, just time consuming.
#26 Rally
Rally
  • 650 posts
Posted 03 September 2011 - 05:08 PM
Sorry if I'm being thick here but are we saying that the Lotus seal A116V0273F is the same thing as Vauxhall supplied Turbo roof seals 9198484? Just to be clear ;)
#27 TazN
TazN
  • 2,931 posts
Posted 12 June 2014 - 09:39 AM
Mine eventually developed some minor leaks so while it's stuck on the driveway figured now would be a good time to fix it. As the adhesive strip they come with is now no longer any good after being pulled of is there anything in particular I should use to re-stick it down?
Was thinking the gum tape you use for vacum bagging looks very similar to the tape that is supplied, or good old pu sealant?
Search isn't bringing up anything useful.
#28 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 12 June 2014 - 03:24 PM
I just used superglue :lol:
#29 PaulCP
PaulCP
  • 6,064 posts
Posted 12 June 2014 - 03:54 PM
I used superglue gel to stick the window cheater seals on, seems to be held solid so may be ok for the roof seal after a good prep. Don't know what it's like to remove though if it does start to come away
#30 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 12 June 2014 - 04:36 PM
sand paper and wire wool gets most sh*t off. :lol:
#31 TazN
TazN
  • 2,931 posts
Posted 12 June 2014 - 06:28 PM
Cheers guys, Stuwy you'll be pleased to know I've ordered a new arch liner, no more duct tape!
#32 PaulCP
PaulCP
  • 6,064 posts
Posted 12 June 2014 - 07:15 PM
No thanks, think I'll stick to Andrex😛
#33 Mat Jackson
Mat Jackson
  • 1,579 posts
Posted 12 June 2014 - 07:53 PM
Is the one shown in the picture the better "turbo seal" or is that the standard one?
#34 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 12 June 2014 - 08:27 PM
holy sh*t
#35 TazN
TazN
  • 2,931 posts
Posted 13 June 2014 - 08:32 AM
there's no pembrey dirt either.
that would be the turbo seal. my na originally didn't have the 'cups' at each corner.
#36 Stonos
Stonos
  • 11 posts
Posted 14 December 2019 - 07:27 PM
What's the part number for these from lotus?
A116V0273F Seal, Door/Front Roof, With A Pillar Drains (aka Header Front Seal) | £84.23 Delivered (that price was back in 2009)
Lotus part A116V0273F is replaced by B116V0273F today.
Can anyone confirm that this part also fit VX220?
#37 martinroger
martinroger
  • 459 posts
Posted 03 February 2020 - 12:52 PM
Anyone knows if B116V0273F is ok to use?
