Radiator Fan Override Switch
Posted 16 June 2011 - 10:05 PM
Posted 16 June 2011 - 10:07 PM
Posted 16 June 2011 - 10:09 PM
Edited by vocky, 16 June 2011 - 10:10 PM.
Posted 16 June 2011 - 10:10 PM
this has to be one of the easiest things to do on a vx220 ......
the negative signal to the fan relay runs below the centre console, simply find the blue/grey wire and connect a switch between it and the chassis, job done
Ok nice one, I tried searching but even through google I came up with nothing.
Also neil, could I have a cheater and instructions or could you fit one for me
Posted 16 June 2011 - 10:21 PM
Posted 16 June 2011 - 10:29 PM
I'd be interested to know whether I could get it to work with one of these Vectra aircon switches I've got here, would fit nicely in place of the now defunct front fog light switch.
Exactly, I have a couple of working switches at home as my front fogs are also non existant.
Posted 16 June 2011 - 10:36 PM
Posted 18 June 2011 - 11:27 AM
Posted 18 June 2011 - 12:13 PM
Posted 18 June 2011 - 12:34 PM
Posted 18 June 2011 - 12:39 PM
Posted 18 June 2011 - 01:31 PM
Posted 03 July 2011 - 02:18 PM
Posted 03 July 2011 - 02:20 PM
Posted 03 July 2011 - 02:23 PM
I'll dig out some pics I took the other day, they're not THAT clear but the wire is certainly there.
Cheers Muncher,
Dying to go out for a blast, but don't want to get stuck in traffic and sit there watching the temp gauge climb up towards the 100. It's probably fine, but I'd like to hve the option of kicking in the fan.
Posted 03 July 2011 - 02:36 PM
It's definitely fine. Do you not think Vauxhall would have set the fan start value in the ECU at less than 106°C if they thought there was the slightest problem for the engine at that temp?It's probably fine,
Posted 03 July 2011 - 02:38 PM
Splice one wire in using one of those connectors to the switch, the other side of the switch I bolted a wire to gear selector mechanism.
It's probably fine,
You're right, time to put the tools back in the garage and go for a blast!
I'll leave the centre channel off and look at it later this evening.
Posted 03 July 2011 - 02:40 PM
Posted 03 July 2011 - 02:48 PM
