Stage 1 Supercharger Conversion.
152 replies to this topic
#61 JG
JG
  • 13,612 posts
Posted 03 March 2012 - 04:13 PM
i wouldn't bother :dry:
#62 CocoPops
CocoPops
  • 17,182 posts
Posted 03 March 2012 - 04:16 PM
The time and effort to remove the pulley... Might as well just got to stage 2 :lol:
#63 Anarchy
Anarchy
  • 2,237 posts
Posted 03 March 2012 - 04:57 PM
That does cross my mind but I have standard exhaust which would be too much to replace at the moment.
#64 smiley
Posted 03 March 2012 - 05:24 PM
Why?
The german version of stage II (sk260) from an official tuner just ticks out the precat, and that's it.
You can live with 240 bhp instead of 250 right?
#65 CocoPops
CocoPops
  • 17,182 posts
Posted 03 March 2012 - 05:44 PM
:yeahthat:
#66 Anarchy
Anarchy
  • 2,237 posts
Posted 13 May 2012 - 08:42 PM
Definately going stage 1 now as the old pulley was ruined removing it thumbsdown
I have the car in bits at the moment and making some progress, my main aim was to get the ECU out and sent off to CMS but I have a few things I cannot figure out.
1. The temp sensor in the standard throttle body inlet tube, does this still get used, where does it go? Part no 29 here.
2. I pressume the whole of the exhaust gas recirculation pipe is removed and the blanking plate from Courtenay is used, this is something I never bought because I thought it was the EGR valve blanking plate which I already have. Part no 2 here.
3. There is a stiff plastic pipe from the existing manifold next to where the throttle body mounts and goes off to the side of the car, it might be charcoal filter related? I cannot see a similar connection on the SC manifold where it would go, is it still used? I cannot find a link to it so might have to take a picture.
4. I bought this Top hose S bend pipe form CMS but on the conversions I have seen they do not seem to use it and I cannot really see the point of it, I think a small piece of aluminium tube might be needed instead. Has anyone used the top hose?
Thank you for any advice.
#67 CocoPops
CocoPops
  • 17,182 posts
Posted 13 May 2012 - 08:43 PM
yes the top hose is needed, to reroute the hose (the silver connector) houses the thermostat.
#68 JG
JG
  • 13,612 posts
Posted 13 May 2012 - 08:48 PM
1, Not used
2. correct you need the little blanker
3. Not sure what you're referring to, a pic might help.
4.Picture of the hose you refer to:
#69 techieboy
Posted 13 May 2012 - 09:22 PM
1, Not used
Huh? It is. That's the intake air temp sensor. It's plumbed into my post filter intake pipe (though Courtenay's just left it hanging in mid-air when they did my conversion).
#70 Anarchy
Anarchy
  • 2,237 posts
Posted 13 May 2012 - 09:28 PM
1, Not used
That is where I suspected it might go, ie make your own hole between filter and TB.
#71 Anarchy
Anarchy
  • 2,237 posts
Posted 13 May 2012 - 09:29 PM
1, Not used
Ah OK so is that aluminium pipe there already I cannot remember seeing one?
#72 CocoPops
CocoPops
  • 17,182 posts
Posted 13 May 2012 - 09:36 PM
No, you buy that piece (as said above it houses the stat)
#73 The Batman
Posted 13 May 2012 - 09:39 PM
Doesn't house a stat
#74 CocoPops
CocoPops
  • 17,182 posts
Posted 13 May 2012 - 09:41 PM
It's a thermostatic switch for the rad fans isn't it?
#75 Anarchy
Anarchy
  • 2,237 posts
Posted 13 May 2012 - 09:43 PM
This is the pipe in no. 3:
#76 The Batman
Posted 13 May 2012 - 09:49 PM
That plugs into the tb Coco, only I'd you want the fans coming on early I see no point in this
#77 CocoPops
CocoPops
  • 17,182 posts
Posted 13 May 2012 - 09:51 PM
Interesting..... I'll drop you a pm then, save clogging this thread :)
#78 techieboy
Posted 13 May 2012 - 09:53 PM
Yep, pull the sensor and the sealing ring out of the existing plastic inlet and drill yourself a suitable hole in the aluminium pipe (or whatever you're using) and refit. Due to our stupid ECU, it's the only temperature sensor we have on the inlet (or exhaust) side of the car and is part of the reason the SC's maps are a bit of a bodge and play safe, as there's no way of telling the ECU what's happening post charger.
#79 techieboy
Posted 13 May 2012 - 09:54 PM
Yep, just a hose joiner on my car. Standard ECU fan control only, here.
#80 smiley
Posted 13 May 2012 - 09:55 PM
1. I put it in a plastic pipe i built between the throttlebody and cone. If you leave it dangeling, it will trigger eml code and fan continuous on. 2. As the connection pipe inside the enigine is allready disconnected via the egr blancking plate you have on, the open hole where the pipe used bolted on to be can be left open, as it's not used anymore. 3. Mine has been put on the SC, but a simple connection in the plastic pipe from nr 1 can also be used. It's just to keep gas fumes out. 4. S bend with small alu straight to bolt it onto oem waterhose.
