Stage 1 Supercharger Conversion.
152 replies to this topic
#101 smiley
Posted 05 June 2012 - 09:03 PM
#102 Anarchy
Anarchy
  • 2,237 posts
Posted 06 June 2012 - 05:28 PM
Doh I feel stupid, I was trying to fit them before the rail was in place and could not figure it out. Thank you for all the help.
#103 Seb.F
Seb.F
    Under Your Bed
  • 6,045 posts
  • Interests:Tech head
Posted 06 June 2012 - 09:47 PM
I should probably think about making a slow start on mine... Looking good though matey.
#104 Anarchy
Anarchy
  • 2,237 posts
Posted 07 June 2012 - 05:45 PM
I am finally making some good progress. Seb can you remember if the SC was filled with oil, I came to check it the other day but it happened to be an Allen key size I did not have.
#105 vocky
Posted 07 June 2012 - 05:52 PM
imperial sized allen key :sleep:
#106 Anarchy
Anarchy
  • 2,237 posts
Posted 07 June 2012 - 05:54 PM
Update 6
I have modded the alternator to fit, the picture pretty much shows how much I removed and there is now a clear gap between the positive and the manifold casing, enough to fit a plastic cap over.
Tip: Fit the pulley bracket and alternator before the manifold, I had the alternator in place and then fitted the manifold but forgot about the bracket and with such long bolts was very awkward to tilt just enough to get the bolts in and the alternator is surprisingly heavy holding it with one hand awkwardly in the engine bay.
Talking of awkward jobs, the manifold bracket had my fingers to the bone trying to get the M10 bolt in, access is just so limited and it did cross my mind that Joe's bracket may be out a bit but no, it went on in the end.
My plan was always to use the standard airbox, I narrowly missed out on a cheap Pipercross Viper so I have stuck to the original plan. I have basically used the existing intake pipe which the sensor can go in and shifted the box further to the outside of the car, fabricated a couple of mounting points and cut the bottom off the box off to get it to fit and be less restrictive.
The ECU has been away to CMS, come back and is now moved to the back wall of the engine bay using the little tubes from the old plastic manifold and screws.
#107 Anarchy
Anarchy
  • 2,237 posts
Posted 07 June 2012 - 06:00 PM
Will have to go see me dad, he says all I go round for is to borrow tools.
#108 Seb.F
Seb.F
    Under Your Bed
  • 6,045 posts
Posted 07 June 2012 - 07:09 PM
From memory it should have oil in it yes!
#109 Anarchy
Anarchy
  • 2,237 posts
Posted 10 June 2012 - 07:36 PM
I am gonna skip a few details, I got it all together yesterday, left it overnight and connected the battery this morning then fired it up and it just worked, not sure what I was expecting but I thought there might be some issues. There was slight high revving for a minute or so as expected, I let it warm up then went up and down the road a couple of times slowly in first and second gear and I could already feel the urgency. It was a little hessitant revving from tickover and stange hearing different noises to what I am used to for the last eight years, the hissing and whining is much louder than expected. It settled down and is smoother now at tickover than before the SC, everything seemed good so I finished the final touches like wheel arch, undertray etc. and went out for a 20 odd mile cruise. I must say I have been beaming today :D , partly because it actually worked but also because the way it drives is awesome, just effortless and exciting and this is going steady staying under 5K or whatever the limit is. It feels like when I first got the car so many years ago, it feels lively again and makes me glad I have stuck with it. I am totally happy with it but I can now see why you could easily get sucked into the modding bug and strive for more but for now this will do. chinky chinky again for all the help and advice. chinky chinky
Edited by Anarchy, 10 June 2012 - 07:38 PM.
#110 Goosenka
Goosenka
    Jeep Driving jolly nice chap
  • 12,716 posts
Posted 10 June 2012 - 07:41 PM
Well done pal
#111 techieboy
Posted 10 June 2012 - 07:51 PM
Well done. Glad it's finally all sorted and working. thumbsup
#112 G-Bob
G-Bob
    Embarrassing VX's in an MX5
  • 8,256 posts
Posted 10 June 2012 - 07:53 PM
Sounds like you are happy with it. thumbsup Will look forward to seeing the results once the map is done.
#113 Anarchy
Anarchy
  • 2,237 posts
Posted 10 June 2012 - 08:00 PM
There is quite a wait to get in at Courtenay apparently but I wanted to see it working before I booked it in, probably be July now.
#114 Nelly Vx
Nelly Vx
    3/3 Of a Queen
  • 5,928 posts
Posted 10 June 2012 - 08:06 PM
Glad you got it up and running , I was a bit hesitant to start mine for the first time ( last weekend ) But well worth the wait , I'm in Courtnay's tomorrow for mapping , feel like a child waiting for Santa :-D !!
#115 Goosenka
Goosenka
  • 12,716 posts
Posted 10 June 2012 - 08:19 PM
You might feel like a child now but after that bloody journey you age a few years.
Good luck tomorrow Nelly
#116 JG
JG
  • 13,612 posts
Posted 10 June 2012 - 08:25 PM
Timbuktu is quite a lot closer.
#117 Nelly Vx
Nelly Vx
    3/3 Of a Queen
  • 5,928 posts
Posted 10 June 2012 - 09:57 PM
It is a fair old hike :lol: , how long will the final mapping take ? Is it all straight forward or Is every one different ?
#118 CocoPops
CocoPops
  • 17,182 posts
Posted 10 June 2012 - 10:04 PM
Depends on stefans availability. We had to wait for an hour or so mid mapping thumbsdown with my car on the rollers but nothing happening.
#119 techieboy
Posted 10 June 2012 - 10:07 PM
I've never had anything less than an 8 hour day there, sometimes more. :wacko:
#120 smiley
Posted 10 June 2012 - 10:19 PM
He does all the vx mapping remote?
