2.0 Lsj And Harrop Tvs Project
68 replies to this topic
#41 vocky
Posted 30 August 2011 - 01:06 PM
The alloy bar arrived today so I knocked up a couple of cam blanks
I also drilled and tapped the oilway (below the cam blank) to M10 and fitted a M10 grubscrew with some threadlocker :closedeyes:
The head porting continues
Edited by vocky, 30 August 2011 - 01:08 PM.
#42 Duncan VXR
Duncan VXR
  • 5,281 posts
Posted 30 August 2011 - 01:08 PM
Looking good Neil ;) DG
#43 vocky
Posted 06 September 2011 - 07:15 PM
Had the head lightly skimmed after finishing the porting.
I also drilled and tapped the inlet manifold fixings to M8, you can't see them in the pic because thats the exhaust side :P
Edited by vocky, 06 September 2011 - 07:19 PM.
#44 vocky
Posted 09 September 2011 - 08:29 PM
the supertech double valve spring kit was fitted with the original saab valves
then the head was fitted to the block using a saab head gasket
then the saab cast roller rockers were fitted along with the hydraulic lifters and compcams blower camshafts
It appears that supertech must have used the later spec cast roller rockers when they designed their z22se/L61 double valve spring kit because they required no modification and have plenty of clearance :blink:
#45 alanoo
alanoo
  • 1,324 posts
Posted 09 September 2011 - 09:27 PM
Shame they are heavier :(
#46 vocky
Posted 12 September 2011 - 07:00 PM
I made a couple of tools to make 'timing up' the Saab cam sprockets much easier, so with my crank degree tool fitted it wasn't too bad a job :closedeyes:
Once the timing was triple checked it was time to seal the engine up with the oil pump and cam cover
Just need to make a cover for the blanked off exhaust auxillary drive and then it's finished :D
#47 alanoo
alanoo
  • 1,324 posts
Posted 12 September 2011 - 07:17 PM
Alloy pulley ? one with a steel hub I hope ?
#48 Exmantaa
Posted 12 September 2011 - 09:42 PM
Alanoo, do you know the ATI dampers? These are said to do a good job on higher rpm ecotecs...
#49 Muncher
Muncher
  • 4,494 posts
Posted 13 September 2011 - 07:28 AM
Looking good :) Alanoo - yea it is steel centred
#50 alanoo
alanoo
  • 1,324 posts
Posted 13 September 2011 - 12:25 PM
They do
they are not better on a stock bottom end, but as soon as you change any rotating mass in the bottom end, they will work better than the stock damper.
The overdrive one needs a small bit of machining on the oil pump cover
#51 vocky
Posted 17 September 2011 - 11:54 AM
The last job was to make an adaptor to allow the LSJ 6 rib pulley to fit the z22se alternator, a spacer and sleeved nut soon had that sorted :D
#52 Muncher
Muncher
  • 4,494 posts
Posted 17 September 2011 - 08:13 PM
Ooh reminds me, it might help if I buy a belt!
#53 Nev
Posted 17 September 2011 - 09:20 PM
Blimey Vocky, I wish I had your skills (and lathes!). If you lived near me, I could learn loads off you, I am sure.
#54 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 17 September 2011 - 09:39 PM
Me me I want one please pritty please ;)
#55 vocky
Posted 18 September 2011 - 07:47 AM
I need you to supply me with a LSJ 6 rib pulley first because it needs machining to use the adaptor I make :closedeyes: [attachment=23400:pulley adaptor parts.jpg]
#56 vocky
Posted 18 September 2011 - 07:49 AM
you are only as good as your tools :D
Are you really sure you would want to live near me :huh:
Because you would have a 2.4 litre Harrop engine if you did :lol:
#57 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 18 September 2011 - 08:36 AM
Wish I had seen your cam timing setup for the saab cams :rolleyes:
#58 Nev
Posted 18 September 2011 - 05:55 PM
I've got nothing against superchargers, I have been vaguely considering adding one to my engine to help beef up the low end. One of those little vortex ones that look like 1/2 of a turbocharger. It would help add some nice torque below 4000 revs. I have heard the trasnition from s/c to turbo is hard to map and control if you use a clutch, so I would be tempted to let the SC boost all the way to 8000 with no clutch or bypass. What do you think ?
Edited by Nev, 18 September 2011 - 05:56 PM.
#59 Bargi
Bargi
  • 4,483 posts
Posted 11 November 2012 - 11:10 AM
Bump... anything further with the build?
#60 TazN
TazN
  • 2,931 posts
Posted 24 January 2013 - 03:17 PM
Another bump on this thread Muncher. Would love to see it up and running :poke:
