Brown-trouser moment when you brake slightly harder than usual, but at the same time the road goes a bit uneven underneath one of the wheels (or down a shallow pothole) and the ABS comes on prematurely.
No brakey-brakey for a bit...
(so far there has been nothing in front of me on the occasions this has happened).
I think this is ridiculously dangerous...BUT - i am not arrogant enough to think that if i disabled the ABS i could manually do it's job in a real ABS-required scenario.
So...I was considering fitting a cut-off switch but im now more for getting it to work properly.
Is an Exige 4 sensor ABS setup the way forward and is it going to be expensive?
There seems to have been a bit of arguing on the forum over whether it's the brakes on the VX220 or whether it's the ABS, that is the cause.
Have people gone down this route and does it solve the problem?
Thanks in advance for any input.
Edited by Loadstar, 26 July 2011 - 10:58 AM.
