Exige Abs?
#21
Posted 29 July 2011 - 11:26 AM
#22
Posted 29 July 2011 - 11:28 AM
#23
Posted 29 July 2011 - 11:31 AM
#24
Posted 29 July 2011 - 11:51 AM
#25
Posted 29 July 2011 - 03:25 PM
#26
Posted 29 July 2011 - 03:57 PM
#27
Posted 29 July 2011 - 07:02 PM
The p/n of the buggy stock ABS unit I ripped off my Opel Speedster Turbo (basically a VXT220) is S108196009 D. Would not give a flying f**k on the letter. That's probably the same shitty unit with the same shitty behaviour. Interesting info!the part number of the Lotus Europa 4 channel unit is S108196009 F.
(sorry for the graphic language, but the stock ABS sucks so much, it would be catastrophic knowing Lotus continued to use it in the Europa S!)
top: lotus elise/exige ABS ECU
bottom: opel speedster turbo ABS ECU
and that's how the packaging ot the elise/exige ABS looks like:
Edited by cs_, 29 July 2011 - 07:06 PM.
#28
Posted 31 July 2011 - 07:06 AM
I am not desperate to sell as I am thinking the next owner may want to fit std wheels and tyres and go back to std ABS setup but if you want it make me a reasonable offer.
cheers
C43
PM sent.
#29
Posted 31 July 2011 - 11:17 AM
Thanks for posting the pictures up with all the part numbers. If I was looking for a second hand 111R one would I need to go off the S108196012 number on the sticker or is the Lotus part number on the item as well as on the bag if you bought it new?
ETA: What other models are these fitted to besides the 111R? Any other Elises & Exiges?
Edited by iVXT, 31 July 2011 - 11:19 AM.
#30
Posted 31 July 2011 - 09:45 PM
#31
Posted 01 August 2011 - 06:01 AM
As far as I know the A120...-number is the Lotus P/N and the S108...-number is the TRW P/N, which is the firm in germany where the ABS has been developed and still is manufactured.Thanks for posting the pictures up with all the part numbers. If I was looking for a second hand 111R one would I need to go off the S108196012 number on the sticker or is the Lotus part number on the item as well as on the bag if you bought it new?
Whe did some group buys here from germany. First time the order has been placed at some british Lotus parts dealer, but the last group buys ran at a german tuning firm. The funny part is, they ordered the ABS ECUs at Lotus/UK, who then ordered the whole bunch of ECUs at TRW/Germany. So the ABS ECUs are manufactured in germany, go to UK and then back to germany. And this for a much cheaper price than any other way we found.
Edited by cs_, 01 August 2011 - 06:02 AM.
#32
Posted 01 August 2011 - 06:04 PM
#33
Posted 01 August 2011 - 06:17 PM
#34
Posted 01 August 2011 - 07:08 PM
Edited by ArticMonkey, 01 August 2011 - 07:12 PM.
#35
Posted 01 August 2011 - 09:08 PM
Todays ABS units are self learning, they cope with almost any wheel diameter difference. You don't belive that? Perhaps you even do not believe that we have here around a hundred converted VXs and most if not every one of them with 17" rims front and rear and many different wheel diameter ratios. Some drive 205/40 front and 235/40 back which makes about 4% difference. Some others (like me) drive 215/45 front and 245/40 rear which only does some 0.4% difference. It's absolutely irrelevant which diameter all these folks drive on their cars, not one of them reported any issues with the ABS. All feedbacks I've got were overwhelming in terms of how much better this ABS works in addition to not showing the erraneous behaviour of the original Vauxhall ABS.as you say it is always impossible to know what to believe on these forums but I have to say I am very sceptical that a ABS setup to run on 16" front wheels will work on 17" without resetting the constants which are a hard learn
You may believe it. Or don't. But the latter would implicate that all the many people actually having experience with the ABS are wrong and you with a believe are right.
Anyway, I don't have to evangelize anyone of you for anything. I love my Lotus ABS and for me it's the very best I could do to my car in terms of safety. Even if I would be the only one who has done it. Do it. Or don't. Your decision. I made mine.
Edited by cs_, 01 August 2011 - 09:09 PM.
#36
Posted 01 August 2011 - 11:29 PM
#37
Posted 02 August 2011 - 07:50 AM
Good isn't it? Definitely worthwhile, especially if you can pick up a used controller at a decent price.Fitted the Exige unit yesterday, it works great and makes the car come alive in that area. Works if you need it to but has not bit once like the old one. So IMHO its a must for the everyday driver who can't predict every road condition. Wheels are 16" front, 17" rear.
#38
Posted 02 August 2011 - 09:20 AM
The Europa unit is setup for 17" which we all know and is 4 channel which again we all know.C43
Hi,
How do you know that the Europa unit is four channel ??
#39
Posted 02 August 2011 - 09:23 AM
#40 Guest_Loadstar (Guest)
Posted 02 August 2011 - 09:33 AM
(im sure most people already know this and it's just me who didn't...)
Apparently a recall was scheduled between 2002 and 2008 to the stock ABS unit on the vx220.
The software/module upgrade was to fix the following issue:-
When accelerating hard and then immediately moving your foot from accelerator pedal to brake pedal, the brake pedal can become hard.
The recall record on my car show this as "expired" but *not* completed.
So given that im experiencing exactly this behaviour and that the recall doesn't say it was completed on my car i think im going to get the module/software update first. (requires ordering the module from Germany)
