bought lotus driver 6012. completely different car. as the day to the night. on the bumpy road the orginal abs driver pumped the pedal upwards and forgave braking. here feel like the driver locks once left front next right front wheel. ideal.
Exige Abs?
#101
Posted 10 June 2016 - 05:57 PM
#102
Posted 08 August 2017 - 01:41 PM
ok so daewoo matiz 4 chanell abs controler (s108196010 c) work too. not perfect but better then orginal vx220 abs. no problems with check abs lamp. Replacement is as simple as with a lotus controller. ebay price is
about 20 pounds.
https://4.allegroimg...1a6859d882cbb84
#103
Posted 08 August 2017 - 04:24 PM
Daewoo abs controller is £50 on ebay http://www.ebay.co.u...NMAAOSwls5Y60Xb
#104
Posted 08 August 2017 - 04:52 PM
about 20 pounds.
Does it need a re-program like the lotus one?
#105
Posted 08 August 2017 - 05:12 PM
Edited by piwo, 08 August 2017 - 05:19 PM.
#106
Lotus one doesn't need 're-programming'. If you buy a brand new one it needs activating. If you buy a used one it is already activated so just plug in and away you go.Does it need a re-program like the lotus one?ok so daewoo matiz 4 chanell abs controler (s108196010 c) work too. not perfect but better then orginal vx220 abs. no problems with check abs lamp. Replacement is as simple as with a lotus controller. ebay price is about 20 pounds. https://4.allegroimg...1a6859d882cbb84
#107
Posted 09 August 2017 - 06:37 AM
#108
Posted 19 August 2017 - 09:26 PM
#109
Posted 19 August 2017 - 09:28 PM
#110
Posted 20 August 2017 - 09:11 AM
#111
Posted 20 August 2017 - 10:27 AM
Edited by Mopeytitan, 20 August 2017 - 10:27 AM.
#112
Posted 20 August 2017 - 01:46 PM
V6 Exige and any other Elise after 2011 is likely a BOSCH ABS system.
Bits off of those are likely not compatible with the Kelsey-Hayes ABS system used on the VX and earlier (2004-2010) Elises. (eg. wheel sensors, hydraulic units, etc.)
It's more advanced though. BOSCH basically sells the 'unlocked' version of these units as the Motorsport ABS system separately. Eye-wateringly expensive though
#113
Posted 20 August 2017 - 04:50 PM
either the daewoo wiring loom has the FR + RR wheel speed sensor inputs swapped at the ABS plug, or the control solenoids/outputs/brake lines are swapped (compared to the Lotus ABS unit).
so which is it? anyone have a Matiz wiring diagram with the pinouts of the ECU control unit?
#114
Posted 20 August 2017 - 05:17 PM
So if I have Exige V6 rear wheel sensors would I need the Exige abs pump or will the vx read them fine?V6 Exige and any other Elise after 2011 is likely a BOSCH ABS system. Bits off of those are likely not compatible with the Kelsey-Hayes ABS system used on the VX and earlier (2004-2010) Elises. (eg. wheel sensors, hydraulic units, etc.) It's more advanced though. BOSCH basically sells the 'unlocked' version of these units as the Motorsport ABS system separately. Eye-wateringly expensive though
#115
Posted 20 August 2017 - 08:00 PM
If you are using the original V6 rear Toyota hubs then you will likely also need the matching V6 front hubs (which are basically the same as the VX but off of later vauxhall models with different type of ABS sensor) and the complete V6 ABS unit (hydraulic + electronic complete)
Edit: you will find that the connectors on the wires coming from the hubs are also a different style on the later Elises.
The BOSCH ABS hub sensors on the 2011 and onward elises are hall-effect sensors (although 2 wire..) while the earlier VX ones are inductive and they are not compatible with eachother. Vauxhall/Opel started using these on their cars somewhere late 2006 or so..
Potential problem area when replacing the original VX ABS units with the later Elise BOSCH units is that the later Elises have gone to a CAN based wiring setup so I'm not sure if the BOSCH ABS unit still provides a separate speed pulse or if it's only sending this data across CAN. If it's not sending any speed pulse then so it may need a little extra CAN to speed pulse converter box to interface with the VX dash and ECU.
Basically you either have to use all the 'old' wheel/hub components and keep the same VX or early Elise ABS unit or use all 'new' components and use the matching V6 ABS unit.
Edited by Arno, 20 August 2017 - 08:01 PM.
#116
Posted 20 August 2017 - 09:24 PM
. Ok thanks. I have all V6 hubs so will get the abs unit. If going to the LCD screen would I still need the converter box? Sorry for all the questions AlIf you are using the original V6 rear Toyota hubs then you will likely also need the matching V6 front hubs (which are basically the same as the VX but off of later vauxhall models with different type of ABS sensor) and the complete V6 ABS unit (hydraulic + electronic complete) Edit: you will find that the connectors on the wires coming from the hubs are also a different style on the later Elises. The BOSCH ABS hub sensors on the 2011 and onward elises are hall-effect sensors (although 2 wire..) while the earlier VX ones are inductive and they are not compatible with eachother. Vauxhall/Opel started using these on their cars somewhere late 2006 or so.. Potential problem area when replacing the original VX ABS units with the later Elise BOSCH units is that the later Elises have gone to a CAN based wiring setup so I'm not sure if the BOSCH ABS unit still provides a separate speed pulse or if it's only sending this data across CAN. If it's not sending any speed pulse then so it may need a little extra CAN to speed pulse converter box to interface with the VX dash and ECU. Basically you either have to use all the 'old' wheel/hub components and keep the same VX or early Elise ABS unit or use all 'new' components and use the matching V6 ABS unit. Bye, Arno.
#117
Posted 20 August 2017 - 09:48 PM
#118
Posted 21 August 2017 - 05:26 AM
The LCD dash should be happy with a direct CAN connection.
The ECU may still want the speed signal pulse.
But that's not too hard to (re)generate. Eg: http://www.co-star.c...-interface.html
Still.. You'd want to investigate the V6 ABS unit first (probably with some V6 Elise schematics) to see if it's sending out a speed pulse or not. It may still do so for radio's and such so you could (ab)use that
#119
Posted 21 August 2017 - 09:45 AM
well, ill answer my own question Matiz pinout/wiring diagram here: http://www.autocats....M2_5_25.en.html vs VX220 pinout/wiring diagram here: https://www.speedste...el-Vauxhall.pdf now dont let the different numbering of the plug pins confuse you (as they did me), and youll see the Matiz uses a COMPLETELY different pin assignment for the wheel sensors. i wont list them as its futile, but a quick look at the diagrams and youll see what i mean. the ECUs are 1 model number different, so hard to fathom that they are completly and utterly different, but wow, the wiring diagrams sure have them hooked up differently. theres a lot of unused pins, so maybe itll take a variety of inputs utilising different pin combinations, but be fcuked if im human trialing an ABS system swap with this many differences. (and even then, the ambiguity with the different brake line outputs isnt resolved) so, im putting the VX ABS back in, and will wait for someone else to human fireball this swap i think
it can't be true. my friend driving with this daewoo abs controler and it works better then standard. mayby daewoo has many different abs and this instruction is one of them,
#120
Posted 21 August 2017 - 11:56 AM
Or maybe it's not working and that's why it seems better!
Bing (1)
