Saab Sump Dipstick Length
Posted 15 August 2011 - 10:11 AM
Posted 15 August 2011 - 11:28 AM
Posted 15 August 2011 - 11:49 AM
Edited by Exmantaa, 15 August 2011 - 11:50 AM.
Posted 15 August 2011 - 12:12 PM
Posted 15 August 2011 - 12:14 PM
Posted 15 August 2011 - 12:31 PM
Like to know how that should be for a Saab sump... And think outer tubes should be the same, but better measure the length from that seat bulge too.
Edited by Exmantaa, 15 August 2011 - 12:31 PM.
Posted 15 August 2011 - 12:39 PM
Posted 15 August 2011 - 01:43 PM
Posted 15 August 2011 - 02:02 PM
Posted 15 August 2011 - 02:51 PM
Posted 15 August 2011 - 02:52 PM
vx220 needs 6 litres from totally emptyAccording manual a Z22Se should have 5liter incl. filter change (actually 4.75L according VX service note.)
Saab sump = +1l, so 5.75-6 liter max!
Posted 15 August 2011 - 04:46 PM
Posted 15 August 2011 - 06:02 PM
Posted 15 August 2011 - 07:53 PM
My saab one protrudes 35mm out the bottom of the tube. Further than the pic of Joes. My VX one protrudes 8mm.
Does that help or do you need a pic?
35mm??? That is really a lot and don't remember that my LSJ/Saab was that long...
Just checked my VX tube and that is about 7-8mm, like in the pic above. 27mm extra for the Saab sounds a lot, but we better compare that to the longer Vectra Z22 stick. I guess the Vectra one in the pic protrudes about 15-16mm, so Saab is then some 20mm longer. (due to different sump and the angled dipstick mounting)
Posted 15 August 2011 - 08:13 PM
Here it is. B207L vs Z22SE.
Posted 01 October 2015 - 11:59 AM
Kicking this based om Martins oil issue topic.
I am also using the Z22SE dipstick in my oem B207
I was told to fill up to the first notch from the bottom. Martin is using the middle of the notches. (not much difference)
If i translate that distance from the Z22SE dipstick, it's a bout 3 cm from the bottom of the dipstick.
If i then apply that to the saab dipstick, i end up quite high.
Are we sure we are not overfilling?
Edited by smiley, 01 October 2015 - 11:59 AM.
Posted 01 October 2015 - 12:02 PM
FYI. Difference between top to bottom for a typical dip stick measurement is 1 L
Posted 01 October 2015 - 12:49 PM
Edited by CHILL Gone DUTCH, 01 October 2015 - 12:50 PM.
Posted 01 October 2015 - 12:54 PM
Posted 01 October 2015 - 12:55 PM
