Rough Idle Solved
#41
Posted 18 August 2011 - 05:28 PM
#42
Posted 18 August 2011 - 06:05 PM
Astra, I think you will be well advised to fit the Pro-Alloy inlet pipe. I think it's quite likely to solve this problem you have. Even if it doesn't it will protect your from the problem in the future. The kit is certainly worth the £100 odd quid and quite easy to install. In fact installing it will give you a bit of an understanding of where your turbo and MAF is and be your first step to learning about your car. Once your tackle these smaller jobs, it's starts to give you confidence about the larger ones and gives you lots of satisfaction. I knew little about my VX when I bought it 3 years ago and now I know just about everything about how the engine works.
If you lived closer to Bristol, I'd be happy to help you fit the kit (for free) and to try and diagnose your car's possible other faults. Let me know if you ever pass by my way.
BTW, even a heavily contaminated air filter will not directly cause the severe problem you described, however if it is badly contaminated it will increase the vacuum in the inlet pipe, so might be having a knock on effect. Thus you should inspect and replace it if necessary.
Edited by Nev, 18 August 2011 - 06:08 PM.
#43
Posted 18 August 2011 - 06:30 PM
Please, give it a rest 2.2_NA, the poor guy was just trying to give a example of performance to indicate the nature and effect of the problem.
Exactly, he has said it all before though.
#44
Posted 18 August 2011 - 06:49 PM
B124E0027F - Intake Pipe - £62.76, a bit cheaper than the Courtenay one
Edited by pjohn151, 18 August 2011 - 06:50 PM.
#45
Posted 18 August 2011 - 07:07 PM
Cheers mate. Just had the pipe off and its all ripped. The pipe to me looks fine except the ripped plastic bit. Wonder what it is making the car slowish
#46
Posted 18 August 2011 - 07:16 PM
#47
Posted 18 August 2011 - 07:18 PM
Stuff a clean rag into the tube or put something over it (and dont forget to extract it prior to re-assembly!).
#48
Posted 18 August 2011 - 08:07 PM
Doesn't look good.
#49
Posted 18 August 2011 - 08:20 PM
When I met up with you a month or so ago I told you I solved my rough idle with iridium plugs - the ones Courtenays sell to be precise! I didn't realise you'd replaced gash spark plus with gash spark plugs… stage 2 needs these to run properly iircToday i put some NGK iridium spark plugs in from the old astra and now the problem has gone
#50
Posted 18 August 2011 - 10:42 PM
#51
Posted 18 August 2011 - 11:18 PM
I give up.
Genuinely thought you were a troll at first, someone goes to see you to help (a complete waste of time it seems ) yet you still go round the same questions over and over.
Of course it's not right you, just spend a fcuking minute thinking about!
Either some attention seeking going on, or you need help.
....and I get told to give it a rest!
#52
Posted 19 August 2011 - 12:42 AM
I give up.
He said he changed his spark plugs, im not a fcuking spark plug geek i dont know which is which. I said to the lad at halfords which ones i would need and i explained the engine wasnt standard its running more BHP, he pointed out the ones i needed. Yes i messed up getting the wrong spark plugs but like i said i didnt know the difference. The person who i met for help wasnt for the rough idle it was to compare the cars to see how mine was performing... the rough idle got mentioned in the convo. No need to be a twat im not a mechanic
#53
I give up.
Bet you got butterflies when you read that and had to post
#54
Posted 19 August 2011 - 12:45 AM
Looks like heat has certainly got to the pipe, so it collapsing under acceleration is your most likely cause...
As I mentioned, if you get the Lotus part, then cut your current pipe up where this bit fits, you'll save £40
The plastic bit looks like its been cut open, does the heat do this?! i'll defo get a pipe from lotus or courtenays cheers
#55
Posted 19 August 2011 - 02:24 AM
Well isn't that great to hear.
#56
Posted 19 August 2011 - 07:25 AM
That looks like the plastic has melted away, and yes the heat has done this. The top of the heatsheild looks ok in the photo, I'd check down the front of the engine to make sure both the upper and lower heatsheilds are there and have not disintegrated...
#57
Posted 22 August 2011 - 04:16 PM
#58
Posted 22 August 2011 - 05:22 PM
#59
Posted 23 August 2011 - 06:48 AM
#60
Posted 23 August 2011 - 10:12 AM
