He is now a bit afraid that this might be a bit overkill in a VX...
Nah.
Would be nice if he would fit the 3.35 first, and do some iat testing, and then try the 3.15
Posted 11 February 2013 - 11:26 PM
Posted 12 February 2013 - 11:02 AM
Posted 12 February 2013 - 11:11 AM
My car will be finished this weekend
Posted 12 February 2013 - 11:20 AM
Posted 12 February 2013 - 01:15 PM
Posted 13 February 2013 - 01:10 AM
Edited by Exmantaa, 13 February 2013 - 01:18 AM.
Posted 13 February 2013 - 09:25 AM
Posted 13 February 2013 - 09:50 AM
Edited by Exmantaa, 13 February 2013 - 09:51 AM.
Posted 13 February 2013 - 10:07 AM
I can start tearing it apart for the Harrop & head.
Posted 13 February 2013 - 10:52 AM
Posted 13 February 2013 - 11:46 AM
Edited by smiley, 13 February 2013 - 11:47 AM.
Posted 13 February 2013 - 01:42 PM
Posted 14 October 2014 - 01:31 PM
Any updates on this - engine and HP Tuners / LSJ set-up still running well..?
Posted 15 October 2014 - 08:19 AM
Well, basically it's running flawless, so not much to upddate on that.
Fitted my ported head + ZZP stage 2 cams and bolted the Harrop charger on top, so I gues it's has around 320-340BHP now.
Did several trackdays with it this year and even with the 80mm pulley you run into the same cooling issues as other Harrops with IAT's in the 80-90°C. And exhaust noise is always an issue for tracks, so now mounted a cat back in to quieten it down...
Power is close to enough, so the focus for the car is shifted now more to brakes (CL5+ but braking is still not what it should be) and handling (testing out some Quantum singles now). Car is still a bit nervous and loose/twitchy, so focuss this winter is on new suspension bushes. Still debating to fit OEM rubber ones or just go balls-out with sphericals.
Posted 15 October 2014 - 12:37 PM
Good to hear the old LSJ engine is holding up well..
Posted 16 October 2014 - 11:20 AM
Good news
I don't know how much you have fiddled with your geo settings, but this might resolve your twitchyness before assuming that your bushes are knackered.
Posted 16 October 2014 - 12:45 PM
Posted 16 October 2014 - 01:22 PM
Good news
Typed a detailed story that is now gone, but basically the geo is ok and the dampers (Hoffman NTR's or Quantum blacks) + 7/8" ARB are pretty good.
Just feels a bit "loose" and not really planted, whatever I change, so time for a bush upgrade.
(Anybody tried out a mix of OEM rubbers and spherical bushes??)
Edited by Exmantaa, 16 October 2014 - 01:29 PM.
