Inner Cv Joint
25 replies to this topic
#1 bunsenburner
bunsenburner
  • 1,042 posts
Posted 30 August 2011 - 03:28 PM
My inner CV joint has been totally destroyed. All (except for one) ballbarings have been crushed into tiny pieces and/or ejected through the CV boot.
The car is at the garage, but I was wondering where can I source one cheaply? Motorfactors will be able to get hold of one, but does anyone on here have a spare?
It seems Vauxhall would like me to remortgage the house to finance one, also only being sold complete with outer joint and shaft.
#2 The Batman
Posted 30 August 2011 - 03:32 PM
Not good if you have destroyed the bearings :blink: Pm eliz for a replacement used driveshaft?
#3 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 30 August 2011 - 08:08 PM
I could rebuild that if it was at my gaf...
#4 techieboy
Posted 30 August 2011 - 08:38 PM
Good luck finding an inner joint from anyone other than Vauxhall. I've been trying for 18 months. The Vauxhall inner joint and boot kit is about £200 and is available without the shaft and outer joint.
#5 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 30 August 2011 - 08:47 PM
I found the same Techie. Also found that the only boot worth fitting is the OE Vauxhall kit as all others fall apart. Not cheap at £60 inc either.
#6 vocky
Posted 30 August 2011 - 08:48 PM
I thought the VX220 CVs are shared with the astra/zafira GSI turbo passenger driveshaft :unsure:
#7 bunsenburner
bunsenburner
  • 1,042 posts
Posted 31 August 2011 - 11:19 AM
Thanks - Liz has sorted me out with a replacement.
#8 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 01 September 2011 - 07:41 PM
Therefore the CV boot should be as well... Any news or info on this?
#9 AstonVauxhall
AstonVauxhall
  • 644 posts
Posted 02 September 2011 - 07:40 AM
When filtering in EPC - using the part numbers for the VX220 bits, it only comes up with VX220 bits.
Only thing possible is - All the VX220 bits, if you buy the joints, it comes with the boot kit as a kit, can't buy the joints on their own. So perhaps with the GSi bits, you can buy them as just the joint, hence why part number would be different?
Boot kits, inner and outer - EPC says VX220 only.
Not to say one doesn't fit though?
#10 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 02 September 2011 - 07:53 AM
So further homework is needed, well volunteered James.
#11 AstonVauxhall
AstonVauxhall
  • 644 posts
Posted 02 September 2011 - 08:01 AM
Ah, ok. I'll be in touch when I've done some digging.
#12 AstonVauxhall
AstonVauxhall
  • 644 posts
Posted 02 September 2011 - 08:41 AM
Ah, ok.
Anyone know the dimensions and particulars of VX220 CV joints?
I'm hoping they correlate with some Astra/Zafira GSi CV joints on eBay.
#13 vocky
Posted 02 September 2011 - 08:54 AM
The vx220 shares the hubs and 2.2 F23 gearbox with the astra G/ zafira A F23 engined cars, therefore the cv joints need to be the same :unsure:
However only the gsi turbo versions have a similar (same ?) inner cv as the vx220
I know they are the same length because I measured up the astra driveshafts when doing my 6 speed conversion
a pic nicked from ebay of a set of astra G/zafira A gsi turbo driveshafts
Edited by vocky, 02 September 2011 - 08:56 AM.
#14 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 02 September 2011 - 09:01 AM
So if the inner CV's are the same then we can assume the inner boots are also the same..?
#15 vocky
Posted 02 September 2011 - 09:03 AM
do you honestly think they made a one off cv for the vx220 or just used an available 'parts bin' item :poke:
#16 AstonVauxhall
AstonVauxhall
  • 644 posts
Posted 02 September 2011 - 09:08 AM
There's no consistency between the Astra/Zafira GSi and VX220 parts.
I can't find just a boot kit for the Astra/Zafira, it always seems to come with extra bits so the part numbers different. Posted Image
#17 AstonVauxhall
AstonVauxhall
  • 644 posts
Posted 02 September 2011 - 09:27 AM
Mike, have you now fitted/parted company with those CV boots I sent you the other week?
#18 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 02 September 2011 - 01:03 PM
Not yet. Fitting one tomorrow and the other is to replace one I pinched off VXT'ED at Le Mans.
#19 AstonVauxhall
AstonVauxhall
  • 644 posts
Posted 02 September 2011 - 01:06 PM
Just wondering if there were any part numbers on the individual parts in the kit, that's all.
I think there is on the grease. It'd be nice if there were on the clips and the boot.
#20 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 06 September 2011 - 10:28 AM
Nothing on the boot or clips James, sorry.
