Larger Throttle Body
Posted 30 August 2011 - 08:10 PM
Posted 30 August 2011 - 08:39 PM
Posted 30 August 2011 - 08:56 PM
so yes a recalibration is needed
Mark had the same thing, swaping the 58 for a 65mm on his NA:
http://www.verboom.n...0824/index.html
Posted 31 August 2011 - 08:59 AM
Posted 31 August 2011 - 09:02 AM
Posted 31 August 2011 - 12:10 PM
Edited by Nev, 31 August 2011 - 12:16 PM.
Posted 31 August 2011 - 12:11 PM
Posted 31 August 2011 - 12:18 PM
Edited by Nev, 31 August 2011 - 12:19 PM.
Posted 31 August 2011 - 12:19 PM
Posted 31 August 2011 - 12:23 PM
Edited by Nev, 31 August 2011 - 12:24 PM.
Posted 31 August 2011 - 12:50 PM
Posted 31 August 2011 - 04:26 PM
If your car is a VXT then you simply don't need a larger TB until you are pushing at least 260 BHP. As it is fly-by-wire operated, as Tehieboy says, you can't just simply replace it with any old TB, the new TB would have to have exctly the same plug.
I had my OEM TB machined out from 57mm to 62mm. If you are still interested I can get it done for you for £200.
What other mods do you have on your car incidentally and what power is making ATM?
It's a turbo car and the body is a machined item from the leh. Power should be atleast 280 now. Just looking to get a high flow top hat to go with the tb,3 inch exhaust then get remapped.
