Anybody Got A Idiot Guide For Opcom
28 replies to this topic
#21 siztenboots
Posted 11 July 2015 - 09:01 AM
I bought one this week and what a b..tard to set up on the laptop with windows 7, needed to download a patch file from Winrar solutions website for the driver to see the interface, got it sorted and now works ok.
linky ?
#22 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    motorsport especially BTCC
    rugby
    eating out
    keeping fit
Posted 11 July 2015 - 11:39 AM
Would a scangauge work? It doesn't say what the code error fault means but you can look the code on Google to tell the fault meaning. Scangauges are a bit pricey though but are dead simple to use, no fannying with a computer. Does an opcom do a lot more specialist things than a scangauge?
Scan gauge is only like a cheap eBay code reader only with lots of other toys but it won't talk to abs or airbag Ecu so you need op com
Edited by christhegasman, 11 July 2015 - 11:40 AM.
#23 Edgeydt50
Edgeydt50
  • 74 posts
Posted 07 February 2016 - 09:30 AM
Without starting another opcom thread...
Finally managed to download the software and when plugging the interface in and testing it things seem to be OK. Then when I go through the options to the engine sections I get this message.
Everything seems to be connected OK and the ignition is on.
#24 Exmantaa
Posted 07 February 2016 - 11:47 AM
As written in that screen, you need to install the special Opcon USB drivers for it to work.
#25 siztenboots
Posted 07 February 2016 - 12:11 PM
I've tried to install the FTDI drivers, with driver signature management disabled , this morning on win 10 and getting no where with it.
http://www.ftdichip....rivers/D2XX.htm
#26 siztenboots
Posted 07 February 2016 - 12:21 PM
seems a lot use the ftdi usb serial converter device , v2.8.30 , I just tried the 2016 latest one from the site but still get a code 10 , even when logged in the DSM turned off.
I can only assume the brick needs to be attached to the obdii port while doing all this
#27 Edgeydt50
Edgeydt50
  • 74 posts
Posted 07 February 2016 - 01:30 PM
But the drivers should be installed for it to pick up the unit which it does
#28 siztenboots
Posted 07 February 2016 - 01:33 PM
I think I must have one of these bad ones with bad firmware installed , as it just does not recognise it as ftdi device
really annoying as I need to see why the airbag light is on
#29 siztenboots
Posted 07 February 2016 - 04:00 PM
I give up
