How To Remove Immobiliser
5 replies to this topic
#1 Muncher
Muncher
  • 4,494 posts
Posted 04 September 2011 - 04:31 PM
I'm trying to remove my immobiliser but have run into a brick wall. I have removed the bracket that supports it and the wiring connector but it just won't come off past the locking barrel. TIS says "remove integral clip" but I can't see it at all. These was one little tab at the back which isn't enough to remove it when it's pressed and I'm completely stumped now :/ Any suggestions appreciated! http://speedsterclub...it, Replace.pdf
#2 Muncher
Muncher
  • 4,494 posts
Posted 07 September 2011 - 12:24 PM
Anyone?
#3 ElizP987
ElizP987
  • 4,037 posts
Posted 07 September 2011 - 03:52 PM
hi Paul, give Rick a ring on 07891 330214 and he'll help you out chinky chinky
#4 ElizP987
ElizP987
  • 4,037 posts
Posted 07 September 2011 - 10:19 PM
Did you sort it? :grouphug:
#5 Muncher
Muncher
  • 4,494 posts
Posted 08 September 2011 - 08:31 AM
Yes thanks Liz, Rick suggested levering it off with a screwdriver but that didn't seem to work, I wasn't far off snapping the screwdriver! But then I tried an adjustable headed wrench, one jaw on the bit the key goes in, the other behind the immobiliser ring and it popped off quite easily :) I just needed to know I wasn't missing anything and wasn't about to break it.
#6 ElizP987
ElizP987
  • 4,037 posts
Posted 08 September 2011 - 08:42 AM
Glad you got sorted chinky chinky
