Project Flying Saucer
831 replies to this topic
#281 Wreelybro
Wreelybro
  • 1,641 posts
    360 Gaming 10-Pin Bowling.
Posted 23 May 2012 - 08:09 PM
OK I'm thinking of getting a new front rubber for over the windshield and down the door shuts. I want the one with the drip catcher. Where the best/cheapest place to get one? I knwo they're expensive!
#282 CocoPops
CocoPops
  • 17,182 posts
Posted 23 May 2012 - 08:14 PM
Errr the group buy last week :lol:
#283 techieboy
Posted 23 May 2012 - 08:15 PM
See if you can piggyback on the group buy in the Group-Buy forum.
#284 Wreelybro
Wreelybro
  • 1,641 posts
Posted 23 May 2012 - 08:22 PM
Ah cheers didn't look there!
#285 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 23 May 2012 - 08:57 PM
There's one left!
#286 Wreelybro
Wreelybro
  • 1,641 posts
Posted 23 May 2012 - 09:14 PM
Not any more!
#287 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 23 May 2012 - 09:24 PM
thumbsup
#288 Wreelybro
Wreelybro
  • 1,641 posts
Posted 24 May 2012 - 08:25 PM
Faffed about a bit on the VX this eve nothing much changed. But have a bloomin water leak from the alloy capped rad I put in... And for the life of me I can't work out where it's coming from.. So looks like its clam off again and have it out.. May have to put the old one back in as did not leak!! What a pain in the Butt!
Anyway heres some of pics of the VX and the Civid togher..
And one on it's own
#289 starlight
starlight
  • 1,790 posts
  • Interests:Oily bits...
Posted 25 May 2012 - 01:12 PM
Looking good, but is the car shy as its not facing the camera? :)
#290 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 25 May 2012 - 04:03 PM
No headlights?
#291 Wreelybro
Wreelybro
  • 1,641 posts
Posted 25 May 2012 - 04:43 PM
Exactly front end not yet done... Water leak to sort out.. I'm building up the rear first and working fwd.
#292 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 05 June 2012 - 07:38 PM
Good day on the car today Matty, pics and update needed though...
#293 Wreelybro
Wreelybro
  • 1,641 posts
Posted 06 June 2012 - 04:10 PM
As Cliffie says we have a good day on the VX. (Cheers for the help and the spare parts bin!) Lots done but most of it you can't see.
Here’s list of jobs done:
  • Oil Change and New Filter – Done.
  • New fuel cut off switch - Installed
  • Wiring in engine bay - Tidied up.
  • Extra holes drilled in the underside of rear clam under the exhaust and reflective alloy tape stuck to inside of clam under exhaust to help with heat.
  • Inside of clam sprayed black (the bit that's seen through the cut-outs.)
  • Clam bolted back down- For the last time hopefully!
  • OEM Rear wheel arch extenders - fitted
  • Roll Bar cover bolted down and Ariel fitted (Cheers Mike!)
  • Engine cover and Cover Release fitted. (Need to adjust a little as is very close at the back by the boot.) Need to get some S/Steel bolts to replace the rusty ones with the rubber caps on that you adjust to get the boot and bonnet level
  • Soft Top locaters and hood fitted - Just needs to align and tighten up hood also adjust the doors a bit now.
  • Painted and fitted the diffuser (Pics Below)
  • Fuel cap fitted
  • Wheel arch Liners – Fitted
  • Fitted original switches back into dash (The ones on the Right of S/Wheel) I have a few wires that have been cut and not sure where they go to will have to sort that. Also Green light is staying on, on the Main Headlight Switch that need fixing. May need help with that!!!!
Next jobs to do are:
  • Replace rubber brake lines with Hel S/Steel Braided ones.
  • Bleed Brake and Clutch System
  • Sort out Electrics
  • Align doors Hood and windows
Then Move onto the front and interior!!
  • Lots more there to do I’ll save that list for another day!
OK so here's the pics enjoy!
#294 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 08 June 2012 - 03:29 PM
looking great, but I would have said white wheels imo can't wait to see it in the flesh
#295 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 12 June 2012 - 08:38 AM
What, white wheels? No Stuwy.
#296 ChrisS1
ChrisS1
    Club OEM
  • 8,360 posts
Posted 12 June 2012 - 10:45 AM
Looking great. Bet you're looking forward to finally getting it on the road thumbsup
#297 Wreelybro
Wreelybro
  • 1,641 posts
Posted 12 June 2012 - 12:07 PM
Yes sure am. It's getting close now.. Just need a few good sunny days to crack in with it!
#298 siztenboots
Posted 12 June 2012 - 12:09 PM
is this going back on the road, or track toy only
#299 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 12 June 2012 - 12:24 PM
Road with track days from what I can gather, deffo not a track slag.
#300 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 12 June 2012 - 01:14 PM
Will you be armourfending/ventureshielding the paintwork Matty after that respray?
