Project Flying Saucer
831 replies to this topic
#401 Wreelybro
Wreelybro
  • 1,641 posts
    360 Gaming 10-Pin Bowling.
Posted 21 July 2012 - 08:07 PM
Nev thanks I checked the clamp bolts on the UJ's they seemed tight could not feel any play. Also could not feel any play in the hardy Spicer joint itself. I'm thinking the worst and it may be a new rack....
Does checking means you tried tightening then up?
Well yes that's the usual!
#402 Wreelybro
Wreelybro
  • 1,641 posts
Posted 21 July 2012 - 08:12 PM
Had another car day today fitted new cabin seals front and rear. Stripped door panels again to fish out the window adjusters that I screwed in too far and they fell off!! Lets hope they stop the water leaks now! Also fitted replacement Lamdas (Not LAMA's!) Cheers Rally this fixed the EML light. However I now have a Airbag light on to replace it! (ScanGuage does no recognise there is a fault :unsure: )
#403 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 21 July 2012 - 08:15 PM
You need op com for that
#404 Bargi
Bargi
  • 4,483 posts
Posted 21 July 2012 - 08:46 PM
Right back from the days hoon - Things to fix:
  • Knocking from steering column wobbling left and right getting a clocking each way (Hoping it just needs to be tightened!)
Well checked the UJ's top and bottom they where both tight and the 13mm and 17mm which hold the rack to the chassis, tight also... Looks like there may be play in the rack :( unless its' in the hardy spicer joints??
Any thoughts?
Plastic cap ends?
Ooooh didn't check those!!! what do they hold on?
Jimmy's your man for checking and replacing them :)
here
#405 Wreelybro
Wreelybro
  • 1,641 posts
Posted 21 July 2012 - 09:29 PM
Ah cool I've got one on order but said would take 2/3 weeks to turn up. (I'll have to borrow Mikes again)
#406 Wreelybro
Wreelybro
  • 1,641 posts
Posted 24 July 2012 - 08:51 PM
Air bag light is now sorted now thanks to Mike and is OpCom! thumbsup
#407 Wreelybro
Wreelybro
  • 1,641 posts
Posted 24 July 2012 - 09:32 PM
Right after hoonage this eve think I've come to the conclusion I need a new rack and I'm not talking Boobs!! Should I get quick rack? If so where do I get one and what make? Discuss........
#408 Wolfstone
Wolfstone
  • 12,987 posts
Posted 24 July 2012 - 09:40 PM
Discuss........
Search is your friend:
http://www.vx220.org...-steering-rack/
http://www.vx220.org...228-quick-rack/
#409 Wreelybro
Wreelybro
  • 1,641 posts
Posted 24 July 2012 - 09:54 PM
Cheers Wolf I was just being lazy!! Found a youtube clip of the exact noise I'm getting so pretty sure it's a rack now.. Time for a wanted post me thinks!
#410 Wreelybro
Wreelybro
  • 1,641 posts
Posted 24 July 2012 - 10:09 PM
Good shout!! BTW nice to meet you the other day..
#411 Tony H
Tony H
    Lotus on Crack
  • 1,729 posts
Posted 25 July 2012 - 06:55 AM
I have the elise parts quick rack fitted and have no opinion on it whatsoever. Happy to help, bro. thumbsup
#412 Anarchy
Anarchy
  • 2,237 posts
Posted 26 August 2012 - 10:18 AM
The YouTube video was probably mine from years ago, it went away for refurb but still came back with the same noise, Titan who refurbed it assured me it was OK and it has been, very annoying though.
#413 Wreelybro
Wreelybro
  • 1,641 posts
Posted 14 September 2012 - 04:31 PM
The time has come to change the sterring rack, now I've been told that there is a Riv-Nut that gets in the way of removal can anyone confirm deny which one I have to remove these are the ones I can see opposite side to the water bottle/battery
#414 vocky
Posted 14 September 2012 - 04:35 PM
it's one which isn't used for anything :sleep: if you look into the chassis section from the drivers wheel arch it's quite obvious which one it is - it is directly in front of the steering box
#415 Wreelybro
Wreelybro
  • 1,641 posts
Posted 14 September 2012 - 04:39 PM
Ah you see the trouble is I would need to jack up and removed the wheel to peek down the chassis section and I've not got my tools at home they are at my garage waiting for me tomorrow I wanted to get a head start this eve and get the rivnut removed this eve.. Could you describe whic one I need to remove?
#416 Wreelybro
Wreelybro
  • 1,641 posts
Posted 14 September 2012 - 04:41 PM
I think it's the one on the left above the row of three but not 100%
#417 vocky
Posted 14 September 2012 - 04:43 PM
not sure which rivnut it is from below the servo, normal method of removal is a long screw driver and a hammer from the wheel arch
#418 Wreelybro
Wreelybro
  • 1,641 posts
Posted 14 September 2012 - 05:04 PM
Dremeled off the one above the three!!! (I've not got a heater in my car atm so not sure which other rivnuts are used..
#419 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 14 September 2012 - 05:36 PM
Not that one Matty, it is the other one. The one you dremmelled out is for the gangle pin bracket.
#420 Goosenka
Goosenka
    Jeep Driving jolly nice chap
  • 12,716 posts
Posted 14 September 2012 - 05:46 PM
Please tell me a Gangle pin exists!! Like something Rambling Sid Rumpol would say :D
6 user(s) are reading this topic
0 members, 6 guests, 0 anonymous users
