Project Flying Saucer
831 replies to this topic
#541 Wreelybro
Wreelybro
  • 1,641 posts
    360 Gaming 10-Pin Bowling.
Posted 17 June 2013 - 01:28 PM
Another job complete:
Fitted some wing supports to stop the insane amount of movement of the Exige GT Rear Wing. I had to make ups some L brackets to secure to the wing itself out of some old steel and the use of the neighbours workshop (He's like 'Norm' from Tim the Toolman Taylor) but he has 2 of everything you could possible need which is proper handy!
Here's the pics complete I didn't take any 'in progress' pics:
#542 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,354 posts
Posted 17 June 2013 - 02:09 PM
Lovely Matty, now when can I take it into work?
#543 siztenboots
Posted 17 June 2013 - 02:11 PM
think it needs a badge on the back
#544 Wreelybro
Wreelybro
  • 1,641 posts
Posted 17 June 2013 - 02:14 PM
I have a VX220 badge to go on but fooked if I can find it.
#545 Wreelybro
Wreelybro
  • 1,641 posts
Mmmm Mike, now how would I get to work lol
#546 chris_uk
Posted 17 June 2013 - 04:02 PM
Matt, if you cant find it i hav a brand spanking new vx220 badge you can have for nothing because i like you :)
#547 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 17 June 2013 - 04:21 PM
If he can find it can I buy it off you please :lol:
#548 Wreelybro
Wreelybro
  • 1,641 posts
Posted 17 June 2013 - 04:23 PM
Cool cheers Chris! Will have a rummage in the garage bring it to Next Time Attack.
#549 Wreelybro
Wreelybro
  • 1,641 posts
Posted 17 June 2013 - 05:24 PM
Just had a rummage and found my badge! Thanks for the offer though Chris much appreciated. Sounds like there's a beer waiting from Stuwy for your one!
#550 Wreelybro
Wreelybro
  • 1,641 posts
Posted 26 June 2013 - 12:43 PM
OK so it's MOT time again booked in for 16:45 let hope it passes!
#551 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 26 June 2013 - 02:11 PM
good luck thumbsup
#552 Wreelybro
Wreelybro
  • 1,641 posts
Posted 26 June 2013 - 06:31 PM
Woohoo! It passed no advisories well only from me to the MOT tester about is attitude to jacking points!
#553 Darcini
Darcini
  • 2,508 posts
Posted 26 June 2013 - 08:39 PM
Result :)
#554 Wreelybro
Wreelybro
  • 1,641 posts
Posted 10 July 2013 - 08:18 AM
Not much done on the VX lately. Although I have fitted an Apexi Cone Filter. Not happy with my installation as is a bit 'agricultural. I've secured to the origional lower airbox mounting with a metal bracing strip it's a 'that'll do to test it' solution.
So I was wondering what others have done to fit to standard N/A engine?
Filter is fitted direct to the OEM pipe just after the airbox it's not a great fit and also too close to the engine so not getting a decent cold air flow plus getting heat soak from the engine.
So if any of you cleaver chaps out there come up with a solution to this I'd be interested in seeing what you've done!
#555 fezzasus
Posted 10 July 2013 - 08:24 AM
Have you seen JG's filter mounting system? It'll be somewhere in his build thread. I would bin the OEM pipe and replace it with a 90 degree elbow, you can then dremel out holes in an aluminium section for the breather hose ect.
#556 Wreelybro
Wreelybro
  • 1,641 posts
Posted 10 July 2013 - 08:42 AM
I did look at JG's soluton not sure if this will work with N/A as he lists for s/c
#557 vocky
Posted 10 July 2013 - 01:06 PM
[attachment=24807:IMGP1477.JPG]
#558 fezzasus
Posted 10 July 2013 - 01:09 PM
there's really no difference between the two.
#559 Wreelybro
Wreelybro
  • 1,641 posts
Posted 10 July 2013 - 01:17 PM
Cheers Vocky, how have you supported the filter end? Can't quite see on my phone!
#560 vocky
Posted 10 July 2013 - 01:21 PM
there is a support bolted onto the coolant tank mounting bracket, I used the same bolt which holds the coolant tank bracket on.
