Project Flying Saucer
831 replies to this topic
#581 Wreelybro
Wreelybro
  • 1,641 posts
    360 Gaming 10-Pin Bowling.
Posted 27 October 2013 - 02:56 PM
Mmmmm wish I had one them. ;)
  :ninja:  :happy:
#582 CHILL Gone DUTCH
Posted 27 October 2013 - 03:07 PM
If you run this engine without the forged pistons to start with you may need extra ahead work when you do SC above 250 bhp which will end up costing more ££s and you will be weakening the engine ( less material ) and will need 86.5 forged pistons.
#583 Wreelybro
Wreelybro
  • 1,641 posts
Posted 27 October 2013 - 03:58 PM
I would put in forged pistons but as I understand they are low comp and as I'm not s/c ing for maybe a season I don't want a N/A with even less power than it has already so you see my dilemma. If I have the cash to pistons and s/c all at once I would definitely do that. Maybe someone can offer some advise?
#584 CHILL Gone DUTCH
Posted 27 October 2013 - 04:12 PM
They are available on different compression But I'm no expert what you will need for NA Would it not be best to build your new engine for SCing when funds allow and just keep going with your current engine until it goes bang
#585 techieboy
Posted 27 October 2013 - 04:14 PM
Leave it alone. The slightly higher compression ratio of the B207 will help redress some of the loss of engine capacity if you're not planning on twatting about with a 2.2 crank.
There's more than enough meat in the liners if you ever do want/need a rebore. My murdered engine proved that, even with a rebore and the forged pistons running in an off-round bore and doing their best to give my engine an on-road rebore as the bearings had disintegrated, the liners held together.
#586 Wreelybro
Wreelybro
  • 1,641 posts
Posted 27 October 2013 - 04:25 PM
Mat I would prefer to do all at once as you say leave current enigine in until it blows but I don't think it has much time left as is loosing water internally and has noisy lifters it's done 92k Going to try and leave it in as long a s possible but not ideal. Also want ro stay 2.2. If for instance I got N/A forged piston and then superchaged with those would that cause any issues Im not looking at chasing power 250-270 is my goal.
#587 vocky
Posted 27 October 2013 - 04:33 PM
you can run 270-280 with the standard z22se pistons, which is plenty with a 4.17 gearbox  ;)
it's the z22se rods which die over 270  :beat:
#588 fezzasus
Posted 27 October 2013 - 04:34 PM
whip the cam cover off and check inside the cam cover for any surface rust, it seems that was the only part not covered in oil at the factory  :wacko:
Cheers Vocky good advice (I'll probably not use the cam cover and use the VX220 OEM one.)
Not going to happen - both cam shafts on the B207 are long which means you can't fit the standard Z22Se cover on.
#589 vocky
Posted 27 October 2013 - 04:37 PM
yes you can, with a little tweak  :P
#590 Wreelybro
Wreelybro
  • 1,641 posts
Posted 27 October 2013 - 04:38 PM
Even If I'm changing the cams? - Vocky?
#591 vocky
Posted 27 October 2013 - 04:54 PM
you can use either cam cover, but obviously there will be certain tweaks required either way
#592 smiley
Posted 27 October 2013 - 04:55 PM
Smaller cams like lsj or zzp will make the Z22SE cam cover fit.
If you want to use the saab cams with the Z22SE cam cover, you need to saw a piece off of the cams.
Vocky will correct if i'm wrong :sleep:
#593 Wreelybro
Wreelybro
  • 1,641 posts
Posted 27 October 2013 - 05:00 PM
Saab cams will be coming out!
#594 vocky
Posted 27 October 2013 - 05:01 PM
for long cams - Saab or lsj you need to either cut the exhaust cam shorter to use the z22se cam cover or use the Saab cam cover for short cams ( including cut down cams) you need a cam blank fitting, this can be used with either cam cover, but you need to modify it more to use the z22se cam cover I have done all three methods, so all are possible
#595 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 27 October 2013 - 05:42 PM
Nice work Matty.
Think I'm going to have to call Neos tomorrow morning and get my deposit paid...
G
#596 Wreelybro
Wreelybro
  • 1,641 posts
Posted 28 October 2013 - 11:43 AM
Nice work Matty.
G
Do it G-Man!
#597 Hammy of hamhouse
Hammy of hamhouse
  • 205 posts
  • Interests:Cars Hifi. Ex Westfield owner.
Posted 30 October 2013 - 05:53 PM
Great project thread and a really nice  looking car at the end
Edited by Hammy of hamhouse, 30 October 2013 - 05:53 PM.
#598 Wreelybro
Wreelybro
  • 1,641 posts
Posted 30 October 2013 - 07:55 PM
Cheers Hammy it's still a work in progress but am pleased so far!
#599 Mopeytitan
Mopeytitan
  • 1,908 posts
    My dogs (love my dogs).
    F1.
Posted 09 November 2013 - 08:24 PM
Just finished reading this thread, you have come out with an amazing car in the end. White would def have been my choice, just looks soo clean.
Looking at buying my first vx when I get back from Norway.
keep up the good work will be keeping an eye on this want to do similar
Al
#600 Wreelybro
Wreelybro
  • 1,641 posts
Posted 10 November 2013 - 12:04 PM
Thanks for the compliment the white really pops in the sunand is better in real life as my camera can't handle the brightness! Engine build is the next step which will be done by Vocky god of engines! Just need to save my pennies for the parts I need. Updates to follow....
Edited by Wreelybro, 10 November 2013 - 12:05 PM.
    Bing (1)
