Project Flying Saucer
831 replies to this topic
#601 CHILL Gone DUTCH
Posted 10 November 2013 - 12:25 PM
Your welcome to my donor engines pistons but there not in best of condition
#602 Wreelybro
Wreelybro
  • 1,641 posts
    360 Gaming 10-Pin Bowling.
Posted 10 November 2013 - 01:29 PM
Thanks Chris I've a doner enigine I need to pull apart once I've checked what the crank and pistons are like I'll let you know should be in bits in the next week or so.
#603 Wreelybro
Wreelybro
  • 1,641 posts
Posted 23 November 2013 - 02:17 PM
OK about time for a update on the engine build it's had the Vocky Built treatment - converted the cam cover to keep the factory look plus will mean I don't have to modify the coil pack to fit.
Also more Vocky Built mods - Oil return bungs made and installed along with the oil plug (for the original turbo oil supply) and coolant plug on the head (for an extra temperature sensor). You can see next to the coolant stub
Also build up photos for 2.2 crank going in with Eagle Rods but standard pistons as not supercharging for now due to cost.
Vocky patent balancer delete done.
Also have some Piper Cams fitted - The is engine almost ready for installation just a couple of Vocky Tweeks to finish off and the purchase of Flywheel Clutch and new slave.
#604 Wreelybro
Wreelybro
  • 1,641 posts
Posted 23 November 2013 - 02:24 PM
At this point I would like to say a massive thanks to Vocky for his skills and knowledge while going through this build oh and of course for the build itself.
#605 Wreelybro
Wreelybro
  • 1,641 posts
Posted 23 November 2013 - 02:38 PM
This is the Cam Cover I tried to remove the paint using Nitromore but as you can see it didn't touch it!!! I decided it was far less effort to get it shot blasted and coated.
Come OK but may get a better one once I've installed engine.
#606 Wreelybro
Wreelybro
  • 1,641 posts
Posted 23 November 2013 - 02:46 PM
Thanks for the offer Chris - but it turned out my pistons where in good nick so was able to sue them.
#607 Wreelybro
Wreelybro
  • 1,641 posts
Posted 23 November 2013 - 02:51 PM
Also got these parts done at the same time:
Adjustable ARB
Spitfire Brace Bar
#608 Wreelybro
Wreelybro
  • 1,641 posts
Posted 23 November 2013 - 03:03 PM
Also have received my Lightened Coolant Bracket which will go on when engine goes in.
#609 CHILL Gone DUTCH
Posted 23 November 2013 - 05:03 PM
I see your not keeping the vacuum pump Is that because of the cams you have
#610 Wreelybro
Wreelybro
  • 1,641 posts
Posted 23 November 2013 - 05:13 PM
Partly plus it's a bit of the unknown. Stay with the OEM setup for now.
#611 Wreelybro
Wreelybro
  • 1,641 posts
Posted 28 January 2014 - 06:51 PM
So had to move the VX from it's current location due to rental reasons and a leaky roof.
Had a result though now paying less for a better Man Cave which is bigger and dryer.
Here are a few pics of the VX's new home
De-spidered and Floor painted
Plenty of room at the front:
Plenty of room at the back
No so much room at the sides though but OK.
#612 Kieran McC
Kieran McC
  • 3,416 posts
Posted 28 January 2014 - 07:01 PM
Paint the walls white it will give you a lot more light to work in
#613 Wreelybro
Wreelybro
  • 1,641 posts
Posted 28 January 2014 - 07:04 PM
Was thinking of doing that but it's a Council one so don't want to go mad!! lol
#614 Wreelybro
Wreelybro
  • 1,641 posts
Posted 28 January 2014 - 07:13 PM
Engine home from Vocky's
Who said you can't get a B207 in Type R?
#615 chris_uk
Posted 28 January 2014 - 08:35 PM
i should really get my saab head on my engine.. i just cant find the motivation at the minute.
#616 Wreelybro
Wreelybro
  • 1,641 posts
Posted 28 January 2014 - 08:46 PM
Yeah know the feeling Chris far too wet and cold. Hopefully be dry at the weekend and I can make a start.
#617 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 28 January 2014 - 09:28 PM
Perhaps some carpet on the walls to stop the doors touching the brickwork?
#618 Wreelybro
Wreelybro
  • 1,641 posts
Posted 28 January 2014 - 09:40 PM
Yup that's another job I need to get done.
#619 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 28 January 2014 - 11:00 PM
when we meeting up for an all white shoot?
#620 Wreelybro
Wreelybro
  • 1,641 posts
Posted 28 January 2014 - 11:05 PM
Soon as I get the enigine mounts done alternator and sort out coolant leak.. Oh and a bit of decent weather. Hopefully make a start on jobs this weekend. It's kind of double work as will need to take the clam off soon to so engine swap but not got all the parts and the funds to do that yet.. So hopefully my current engine will be good enough till then.
