That's cam overlap I also get this below 2000 rpmfunnily enough had a similar situation today. does it actually misfire under load when driving? did you fit Stg 2 cams?
Project Flying Saucer
#701
Posted 23 March 2014 - 08:13 PM
#702
Yes and yes Piper cams BP270HT.funnily enough had a similar situation today. does it actually misfire under load when driving? did you fit Stg 2 cams?
#703
Posted 23 March 2014 - 08:16 PM
#704
Posted 23 March 2014 - 08:18 PM
Yeah they are but came new with engine.I assume the plugs are different in the B207? I'd check them.
#705
Posted 23 March 2014 - 08:30 PM
On the basis that everything else on the engine is tried and tested on your old engine (injectors, coil pack, so on), I'd check the spark plugs.
#706
Posted 23 March 2014 - 08:32 PM
hang on, so what have you got and hows it all fitted? So new Saab motor with a Z22SE Cam cover and Saab coil pack? What ECU are you running with it? Are the Piper Cams suited to forced induction?Yeah they are but came new with engine.I assume the plugs are different in the B207? I'd check them.
#707
Posted 23 March 2014 - 08:39 PM
#708
Posted 23 March 2014 - 08:55 PM
I find it's quite the opposite, usually a bad electrical connection on the injectors
#709
Posted 23 March 2014 - 09:01 PM
#710
Posted 23 March 2014 - 09:35 PM
Disconnect each inj. one by one to see which cylinder misfires. (Or if you have an OPcom device, you can check that with the fault diagnosis)
Basically you just have a Stock Z22SE with Piper cams and probably some head work, only build up from a new saab engine block. Right?
#711
Posted 23 March 2014 - 09:39 PM
#712
Posted 24 March 2014 - 07:49 PM
#713
Posted 24 March 2014 - 09:19 PM
Lol You heard it here firstDid you stretch the coil pack springs
#714
Posted 24 March 2014 - 10:40 PM
It's fixed! Thanks Lee and Vocky for the tips. It ended up being the Coilpack springs that needed a stretch! No to sort out a couple of minor leaks and pit some miles on it.
sweet, time for some pics
#715
Posted 24 March 2014 - 10:45 PM
#716
Posted 29 March 2014 - 06:29 PM
#717
#718
Posted 29 March 2014 - 06:34 PM
Hope this isn't going to affect croftGot 100 miles on the vx220 today engine is all good..... However the gearbox isn't! Got a nasty bearing noise on aacceleration and shifting down box, dip clutch it's foes away. So is looking like it's engine out again! And either replacement gearbox or get mine rebuilt. Either way I'm fed up!
#719
Posted 29 March 2014 - 06:51 PM
Er well unless someone is going to give me a gearbox and fit it for me tomorrow I won't be in the vx220 but will still be going to Croft albeit in my trusty Honda!Hope this isn't going to affect croftGot 100 miles on the vx220 today engine is all good..... However the gearbox isn't! Got a nasty bearing noise on aacceleration and shifting down box, dip clutch it's foes away. So is looking like it's engine out again! And either replacement gearbox or get mine rebuilt. Either way I'm fed up!
#720
Posted 29 March 2014 - 07:22 PM
