Project Flying Saucer
831 replies to this topic
#721 Wreelybro
Wreelybro
  • 1,641 posts
    360 Gaming 10-Pin Bowling.
Posted 29 March 2014 - 07:26 PM
Probably be using Mikes
#722 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 29 March 2014 - 07:27 PM
That's bad news Matty :( I have some bits from an f23 if you need any.
#723 CHILL Gone DUTCH
Posted 29 March 2014 - 07:29 PM
Silver lining At its best
#724 Wreelybro
Wreelybro
  • 1,641 posts
Posted 29 March 2014 - 08:10 PM
I'm taking over to mates race shop tomorrow hopefully he'll be able to properly diagnose issue.
#725 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 30 March 2014 - 12:50 PM
Probably be using Mike's
Mine's going to have a busy day as Chris and Steve are booked for time in the car as well.
#726 Wreelybro
Wreelybro
  • 1,641 posts
Posted 30 March 2014 - 02:59 PM
Right gearbox sourced and bought being ferried back to MK tomorrow. 37k box for £50 bargain! Now just have to take it out all over again! Need to contact Courtenays as well to see if I can get a refund on Clutch Slave that blew.
#727 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 30 March 2014 - 05:32 PM
Good news Matty!
#728 The Batman
Posted 30 March 2014 - 05:52 PM
get them to replace it and fit it to the '37k box'
fitted one yesterday and it works fine, so you must have got a duff one..
#729 chris_uk
Posted 30 March 2014 - 06:22 PM
Good news!
#730 Wreelybro
Wreelybro
  • 1,641 posts
Posted 31 March 2014 - 01:03 PM
Gearbox arrived this morning! Faulty slave sent back to Courtenays. Just need time to fit it all again! Think I'm having a VX220 groundhog day!
#731 CHILL Gone DUTCH
Posted 31 March 2014 - 02:41 PM
It is lighter nights
#732 Wreelybro
Wreelybro
  • 1,641 posts
Posted 31 March 2014 - 08:12 PM
Gearbox home and de-greased! Run out of daylight only get an hours worth...
#733 Wreelybro
Wreelybro
  • 1,641 posts
Posted 01 April 2014 - 07:27 PM
Clam off today and gearbox cleaned up a bit more. No more time available to me now until Sunday! Hopefully get engine out and gearbox swapped and back in. If I'm lucky.
#734 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 01 April 2014 - 07:59 PM
Gearbox change with engine in place..?
#735 Wreelybro
Wreelybro
  • 1,641 posts
Posted 01 April 2014 - 08:09 PM
Nah not worth the hassle pull the whole thing out.
#736 GeorgeBC
GeorgeBC
    Needs a cheaper hobby
  • 3,138 posts
Posted 01 April 2014 - 08:58 PM
:yeahthat:
Waste of time having to remove and refit the clam as well as disconnecting everything and lifting out. Not to mention replacing brand new coolant etc!
Edit:- meant to quote Cliffie saying change box with engine in place.
Edited by GeorgeBC, 01 April 2014 - 08:59 PM.
#737 Wreelybro
Wreelybro
  • 1,641 posts
Posted 01 April 2014 - 09:08 PM
Clam already off George. Oil needs changing in engine and box anyway and have coolant already. I'd rather take it all out tbh easier to work on.
#738 CHILL Gone DUTCH
Posted 09 April 2014 - 08:39 AM
How you getting on matt with g-box, Just a quick question which dip stick did you use with the Saab engine the oil I was losing was coming from the dip stick Chris
#739 Wreelybro
Wreelybro
  • 1,641 posts
Posted 09 April 2014 - 12:00 PM
gbox this weekend. I used the old dipstick.
Edited by Wreelybro, 09 April 2014 - 12:01 PM.
#740 Wreelybro
Wreelybro
  • 1,641 posts
Posted 15 April 2014 - 07:24 PM
Well time for an update - Fitted the replacement gearbox last weekend all whet well new slave fitted (replacement from Courtenays) everything as it should be all gears working etc...
Then came the road test...
1st.....
2nd.....
3rd.....
4th.....
Oh......
Oh dear......
Oh balls.....
Exactly the same noise at my original one I took out.
Get a noise (to quote Slindborg - sounds like a can of peanuts being spun around) when under load gets worse in higher gears. Also going down box the same noise on hard deceleration. Foot on clutch and it goes away, driving like a granny don't hear noise much at all.
So off I popped to a transmission specialist who has said sounds like could be the pinion bearings or first motion shaft.
To say I'm gutted / fed up / pissed off pulling engine in and out is an understatement..
Anyway looks like that is what I will be doing this Good Friday and Weekend once again!! (only the 4th effin time!)
Box is coming out and going to be rebuilt....... (Should of done this first but hindsight is doesn't really help... just pissed me off more!!!)
So if anyone is bored at the weekend and wants to lend a hand I'll be up to my armpits in Vx220 once again....
