P0130 In A Z20Let Running Fine
13 replies to this topic
#1 mulletmaster
mulletmaster
  • 471 posts
Posted 15 September 2011 - 09:09 PM
Hi guys roughly every 100-150miles my car will throw up a p0130 eml. It's running great, no changes at all, search (from other engines) tells me it's the 'front lambda' Just to make sure before i drop £130 I presume that means the pre cat lambda sensor? I would have thought it would have showed some other sign but the light, but it's been on 3 times now(after being cleared) so I'm not going to ignore it? Fuel economy hasn't changed by the way, 35-40mpg
#2 siztenboots
Posted 16 September 2011 - 08:38 AM
just ignore it , fitting a new lambda won't fix it, most likely an air leak around the exhaust manifold.
pull fuse 8 for 30 mins, if the light annoys that much.
cheapest place imo for oem plug n play lambda is here
My link
use code PARTS20CC for 20% extra off
FREE DELIVERY
GRAND TOTAL (inc VAT): £50.88
#3 SteveA
SteveA
  • 9,156 posts
Posted 16 September 2011 - 09:58 AM
Could be all sorts of things; Air leaks from mani or the v band join Duff lambda Dodgy Wiring Faulty ECU I think I have a font Lamdba you can borrow to see if that is the issue. If it solves the problem you can pay me for it, if not send it back. It's an OEM Bosch sensor and I'll take £50 if I've still got it.
Edited by SteveA, 16 September 2011 - 10:00 AM.
#4 mulletmaster
mulletmaster
  • 471 posts
Posted 16 September 2011 - 11:50 AM
Thanks for the advice guys! Il dig around The cheap and easy bits and if they don't cure it il leave it be, certainly not going to swap ecu over it!
#5 siztenboots
Posted 16 September 2011 - 12:19 PM
you might try and reseat the vband clamp and fit this 90424370 - Turbo to precat gasket 1 of
#6 SteveA
SteveA
  • 9,156 posts
Posted 16 September 2011 - 02:02 PM
Make sure if you are testing wiring you unplug the ECU (X31) connector as certain pins don't like to have current passed down them. I had to replace my ECU due to this thumbsdown
#7 mulletmaster
mulletmaster
  • 471 posts
Posted 16 September 2011 - 05:29 PM
Thanks for the ongoing advice! Shame our stupid plastic cars have the hardest access ever to the exhaust manifold side to check for leaks!
#8 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 16 November 2013 - 01:23 PM
I've got this issue with my VXT. I replaced the pre-cat lambda sensor and reset the EML via OP-COM but now 50 miles later it has come back on.
Errors I get are:
P0130 - O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)  (08) - Not present P0130 - O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)  (09) - Present
No leaks in the manifold that I or the garage could find.
Strange one.
#9 Alby
Alby
  • 86 posts
Posted 07 May 2016 - 06:39 PM
I've got this issue with my VXT. I replaced the pre-cat lambda sensor and reset the EML via OP-COM but now 50 miles later it has come back on.   Errors I get are:   P0130 - O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)  (08) - Not present P0130 - O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)  (09) - Present   No leaks in the manifold that I or the garage could find.   Strange one.
What did you do in the end?
#10 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 07 May 2016 - 06:46 PM
Wow this is an old one. Anyway the MAF was fcuked so I replaced it with a new OEM one and it's been fine since. Touch wood.
#11 siztenboots
Posted 08 May 2016 - 11:26 AM
I got fed up with this on the old CS map, so I decided to fix it with my latest remap.
Its in the function FKHABMN
#12 Nev
Posted 08 May 2016 - 01:06 PM
Surely the pre-cat lambda reading is rather important as it is used for idle and low rev stoemetric...?
#13 Crunchie
Crunchie
  • 473 posts
  • Interests:Lots of different things, in lots of different places
Posted 21 January 2017 - 03:39 PM
My EML is on with P0130 error too but apart from the light being on youd never know any difference ad its running fine I would have thought it woukd be down on power if there were any leaks. It came on whilst stuck in traffic and the engine got hotter than normal only upto 98 degrees so nothing too hot. Dont know if that would have any beating on the matter.
#14 tibby
tibby
  • 504 posts
  • Interests:POWER
Posted 21 January 2017 - 03:51 PM
+1 , had this also last year.... a P0130 can be.... Disconnected plug to the sensor Possible corrosion in the sensor connector Damage to the sensor wiring to the ECM Fuel system having poor volume to the engine (i.e. Fuel Pump or other component) Intake vacuum air leaks Loose connections in the air or fuel systems Mass Air Flow sensor (MAF) reading out of range Manifold Absolute Pressure sensor (MAP) reading out of range Evaporative Emissions (EVAP) leaks HO2S sensors reading out of range Leaking fuel pressure regulator The ECM is damaged
