408Bhp / 373Ft-Lb Stage 5+ 2006 Vx220 Turbo (Met Black)
#301
Posted 25 September 2012 - 09:29 AM
#302
Posted 25 September 2012 - 11:08 AM
Question for you... Why can't the Adaptronics run the DBW? The SSC kit for the Toyota Lotus uses a reworked adaptronics and AFAIK has an on-board H-bridge to control the DBW. When you get into standalone ECU's its terrific to have the flexibility of DBW, I for one would not want to go back to a cable throttle.
Yes the higher model does support DBW, but costs increase and not tested in anger fully tbh Chris
DG
#303
Posted 26 September 2012 - 07:14 AM
#304
Posted 26 September 2012 - 07:43 AM
#305
Posted 26 September 2012 - 07:49 AM
#306
Posted 26 September 2012 - 08:03 AM
and put the fuel injection wiring cover back on , also the cable loom by the cam cover could do with being all clipped back in nicely
Still very much work in progress Steve!
#307
Posted 26 September 2012 - 08:28 AM
#308
Posted 26 September 2012 - 08:47 AM
#309
Posted 26 September 2012 - 08:49 AM
Nice touch sir
#310
Posted 26 September 2012 - 08:53 AM
Is it just me or has the courtenay been replaced by that VXR logo?
#311
Posted 26 September 2012 - 08:57 AM
#312
Posted 26 September 2012 - 09:01 AM
#313
Posted 26 September 2012 - 09:04 AM
#314
Posted 26 September 2012 - 09:20 AM
Just out of interest what are we looking at for a stand alone ECU?
Steve, still getting final specs for the pedal / tb kit and a price for this. I will have 5 completed at the end of this year at different specs and will put me in a better place to have set priceing depending on if you want the extras - traction control etc and also throttle body specs - ie oe size or upto 70mm. And also if you want turn key or diy install
Simons one is working a 64mm tb currently and passed the pain onto Dave to work it, nbot used this one previously so bit of work need (ok lot of wroking the tb lol)
I will when back be finishing a stock vxr setup on the standalone which will give a good indication of differences between normal stg2-4 cars on oe management
Price for the ecu / loom / install side of it there give or take and expect about £1200 for install, hardware and mapping turn key excluding the pedal / tb side of things
Luke your car is next to Simons waiting for a weekend to finish some fabrication at Daves before upto Chris RR
DG
#315
Posted 26 September 2012 - 09:24 AM
#316
Posted 26 September 2012 - 09:34 AM
#317
Posted 26 September 2012 - 10:21 AM
#318
Posted 26 September 2012 - 10:47 AM
you do know webcon sell the throttle bodies parts seperately, so you could buy the pedal, pedal end cable bracket and throttle cable from them
Edited by vocky, 26 September 2012 - 10:48 AM.
#319
Posted 26 September 2012 - 11:13 AM
#320
Posted 26 September 2012 - 11:42 AM
