408Bhp / 373Ft-Lb Stage 5+ 2006 Vx220 Turbo (Met Black)
#381
Posted 13 October 2012 - 05:47 PM
#382
Posted 13 October 2012 - 06:14 PM
#383
Posted 13 October 2012 - 06:15 PM
#384
Posted 13 October 2012 - 06:24 PM
a really solid, reliable well mapped 400ish would be ideal I reckon - should achieve that with this setup and aftermarket ECU :>
Exactly what I after
#385
Posted 13 October 2012 - 07:16 PM
#386
Posted 13 October 2012 - 07:25 PM
#387
Posted 13 October 2012 - 07:30 PM
Edited by Aimy, 13 October 2012 - 07:31 PM.
#388
Posted 13 October 2012 - 08:06 PM
#389
Posted 13 October 2012 - 08:07 PM
I'm just glad you don't live closer Simon as those evil modification thoughts could pop back into my head again lol
I can only assume you are a hairdresser to the stars Aimy as you budget for mods seems excellent!
#390
Posted 13 October 2012 - 08:17 PM
#391
Posted 13 October 2012 - 08:23 PM
#392
Posted 13 October 2012 - 08:26 PM
#393
Posted 13 October 2012 - 08:39 PM
#394
Posted 13 October 2012 - 08:43 PM
Just spoken with DG
The only problem Chris is having at the moment is holing the power back!!!!
The response is virtually the same as a K04 but... At 3500rpm its producing 250bhp... It then goes linier and at 4000rpm is producing 28psi!
Chris is amazed at the response and power the Garrett's producing and more mappings required to try and smooth the delivery out!
So very very pleased with where we are at right now, no boost leaks, no coolant or oil leaks, perfect running temps & AFR's, just got to try and control a turbo that just wants to BOOST!
To be continued...
Excellent news, 250 BHP @ 3500 RPM is about double what mine makes. Makes me realise how badly I need to put some verniers in mine and check the timing of my Piper cams.
#395
Posted 13 October 2012 - 08:50 PM
Stock boost solenoid works on quite a surprisingly high frequency. Also, they aren't very reliable and we have taken to upgrading them on all our high powered conversions.
Hi Chris,
Are you using the solinoid off the vag world ones?
#396
Posted 13 October 2012 - 09:18 PM
#397
Posted 14 October 2012 - 07:19 AM
Hi Chris,
No, we use a proper industrial one. Think they are made by mac, aem turbosmart etc all rebrand them
#398
Posted 14 October 2012 - 07:20 AM
Mapping OE solenoid throught the ECU is 'cleaner', however a boost controller is sooooo much easier and gives more direct control over boost (instead of it changing with the weather, literally). As long as the fuel, ignition, MAF, etc. are mapped for that boost level then no reason not to run a boost controller.
If your ecu has proper closed loop boost control (which I assume this one does) there is absolutely no reason whatsoever to add a boost controller.
#399
Posted 14 October 2012 - 07:31 AM
#400
Posted 14 October 2012 - 07:41 PM
and also to Dave Hardwick for just being amazing - is there nothing this man can't fabricate & design to the highest quality?! - Thankyou!!!
and Chris @ EFi - such a modest guy who's so so talented
So lets see what tomorrow brings but the end is definatly in sight!
Edited by MrSimba, 14 October 2012 - 07:44 PM.
