Aftermarket or OE ECU? Some OE are a pig to map to stop the boost ringing when you change turbos. If decent aftermarket, then no there should be no need for a boost controller.
Mapping OE solenoid throught the ECU is 'cleaner', however a boost controller is sooooo much easier and gives more direct control over boost (instead of it changing with the weather, literally). As long as the fuel, ignition, MAF, etc. are mapped for that boost level then no reason not to run a boost controller.
If your ecu has proper closed loop boost control (which I assume this one does) there is absolutely no reason whatsoever to add a boost controller.
408Bhp / 373Ft-Lb Stage 5+ 2006 Vx220 Turbo (Met Black)
#401
Posted 14 October 2012 - 08:35 PM
#402
Posted 14 October 2012 - 10:02 PM
Edited by Aimy, 14 October 2012 - 10:02 PM.
#403
Posted 14 October 2012 - 10:22 PM
After all, if people like Simon and Duncan didn't push the boundaries we would all still be driving OEM factory cars.
Nothing wrong with driving an OEM factory car! You make it sound like its inferior Nev.
#404
Posted 14 October 2012 - 10:26 PM
#405
Posted 15 October 2012 - 06:17 AM
I don't think its that... I just don't think Nev reads or thinks about his posts before sending
#406
Posted 16 October 2012 - 09:38 AM
#407
Posted 16 October 2012 - 09:42 AM
Especially as the vast majority of OEM cars are better than modified ones
#408
Posted 16 October 2012 - 09:48 AM
Just spoken with DG
The only problem Chris is having at the moment is holing the power back!!!!
The response is virtually the same as a K04 but... At 3500rpm its producing 250bhp... It then goes linier and at 4000rpm is producing 28psi!
Chris is amazed at the response and power the Garrett's producing and more mappings required to try and smooth the delivery out!
So very very pleased with where we are at right now, no boost leaks, no coolant or oil leaks, perfect running temps & AFR's, just got to try and control a turbo that just wants to BOOST!
To be continued...
Excellent news, 250 BHP @ 3500 RPM is about double what mine makes. Makes me realise how badly I need to put some verniers in mine and check the timing of my Piper cams.
thats approx 370 lbf of torque which is same as mine, and sounds like massive fun on track if it wants to give even more at more rpm.
#409
Posted 16 October 2012 - 09:53 AM
Just spoken with DG
To be continued...
What have you had done to yours?
#410
Posted 16 October 2012 - 10:35 AM
Edited by MrSimba, 16 October 2012 - 10:36 AM.
#411
Posted 16 October 2012 - 11:11 AM
#412
Posted 16 October 2012 - 11:24 AM
#413
Posted 16 October 2012 - 04:59 PM
#414
Posted 16 October 2012 - 07:15 PM
Looking forward to seeing the figures when it's done!
Me too!
#415
Posted 16 October 2012 - 07:44 PM
#416
Posted 16 October 2012 - 08:09 PM
#417
Posted 16 October 2012 - 08:12 PM
#418
#419
Posted 16 October 2012 - 08:14 PM
#420
Posted 16 October 2012 - 08:19 PM
