Exige Style Side Wheel Arch Vents
Posted 13 October 2011 - 05:41 PM
Functional or otherwise has anyone done this mod and if so what did you use? It looks from the picture that the actual Exige grille may have been used, how do these secure in and does anyone have a close up pic? I was hoping to make use of some sort of ready made grille that has a lip to slot it in flush to the body panel whilst covering the unpainted cut edges. If what is used on the Exige will achieve this then great if not can anyone think of anything else that would fit the bill? I have some RX-8 vents which are a nice shape but too big.
Posted 13 October 2011 - 05:54 PM
Posted 13 October 2011 - 05:55 PM
Posted 13 October 2011 - 07:01 PM
Posted 13 October 2011 - 07:05 PM
Posted 13 October 2011 - 07:26 PM
Posted 13 October 2011 - 07:28 PM
Posted 14 October 2011 - 08:16 AM
Posted 14 October 2011 - 09:34 AM
I didn't think those vents were real on the Exige anyway?
They are real in the sense that they have actual grilles that pass through the clam and are not just stuck on top of the body work. Whether they actually do anything benficial or are just for looks I don't really know...
It seems there is a fine line between a vent that is intended to aid airflow out from under the bonnet (of a front engined car?) those that are used to manipulate pressures within the wheel arches and those that are purely for styling purposes. It does not look like the inner arch in the pic below has any sort of cut out to allow air to exit the vent. Instead of which it just seems to go through to the enclosed void of the sill section which would suggest it serves no purpose?
If I was to do this mod with the view of achieving more than just looks would there be any reduction in front end lift if I was to mould in a duct behind the wheel that would allow pressure to escape out to the side?
Posted 14 October 2011 - 09:39 AM
I have several front vent designs done here if you want to have a look. Done on a range of cars that may be getting them soon.
I have also done a range of rear vent designs.
Would post pics but cant remember how/be bothered etc etc.
I'm not sure exactly what you mean or if / how they could be implemented on the VX but regardless I would be interested in taking a look at what you have come up with.
Posted 14 October 2011 - 09:43 AM
Posted 14 October 2011 - 12:12 PM
Posted 14 October 2011 - 03:58 PM
There might be a hole into the wheel arch, but just not visible because it's hiding behind the edge of the wheel arch.
Posted 15 October 2011 - 09:21 AM
