1500 miles, or so.
Completely missed the profile location
Posted 11 November 2011 - 04:17 PM
1500 miles, or so.
Posted 11 November 2011 - 04:22 PM
1500 miles, or so.
Posted 11 November 2011 - 07:46 PM
1500 miles, or so.
Posted 12 November 2011 - 07:35 PM
Posted 12 November 2011 - 10:57 PM
Edited by Rally, 12 November 2011 - 10:58 PM.
Posted 13 November 2011 - 09:15 AM
Maybe cut the hole the same shape as those kidney things that cover the gubbins in the doors - then plug them with those? That is supposing you could get hold of those parts for a reasonable price, and that its even worth it
Hey Smiley, how did you go about repairing the temporary hatch you cut in the front sill?
Glue 2 squares against the rear side of the sill, with small parts sticking out to the middle.
Then put the cut out piece back. I did not glue it back in, just in case i need back entrance to it.
Then cover that complete clam part with a few layers of black foil.
The sill cover removal trick that is used in the UK is a cleaner solution, if you have the fiddeling time, and don't mind the 2 white foam pieces destroyed.
Posted 13 November 2011 - 10:28 AM
Posted 27 December 2011 - 03:45 PM
Of course the gasket goes on, before putting it on the engine:
Posted 27 December 2011 - 03:52 PM
Edited by vocky, 27 December 2011 - 03:52 PM.
Posted 27 December 2011 - 04:21 PM
Posted 27 December 2011 - 04:41 PM
do not modify the gasket, the CMS mapping cannot cope with the extra flow created
and you don't need to use any gasket sealant, just clean the mating surfaces
Posted 27 December 2011 - 04:42 PM
Use the search!Great write up! A couple of quick questions: what is the (new) parts cost of an SC conversion? Whats the ball park figure for getting the S/C itself second hand?
Posted 27 December 2011 - 04:48 PM
Use the search!
There's tonnes of info over on z22se.co.uk as well.
Posted 27 December 2011 - 05:16 PM
Edited by smiley, 27 December 2011 - 05:18 PM.
Posted 08 January 2012 - 10:10 AM
Just noticed no pictures on the map sensor swap, but hope that's abvious.
Posted 08 January 2012 - 10:53 AM
Posted 08 January 2012 - 12:46 PM
Lee and I (with the help of Vocky) have done two conversions using only new parts. costs around £4k, maybe slightly more.
Posted 08 January 2012 - 01:03 PM
Posted 08 January 2012 - 04:04 PM
I feel stupid but it's not.
Where do you put it?
And where do you put the sensor that was in the plastic inlet pipe?
Edited by smiley, 08 January 2012 - 04:04 PM.
Posted 08 January 2012 - 04:05 PM
