it is impossible to do it for 2k with new parts.
2k?! Who managed that? I thought the £4k each for JG and I was good going.
Or did you think that JG meant 2 conversions for £4k total?
Posted 08 January 2012 - 04:06 PM
Posted 08 January 2012 - 04:08 PM
Posted 08 January 2012 - 04:09 PM
Posted 08 January 2012 - 07:31 PM
I feel stupid but it's not.
Where do you put it?
And where do you put the sensor that was in the plastic inlet pipe?
Don't worry; there are no stupid questions on a conversion like this.
Have a look on lhe left side, where you see the map sensor in the inlet manifold.
As for the plastic pipe your oem setup has; it currently has 3 connectors in it:
- air sensor (which has to be moved to a location before the throttle)
- valve cover breather (either reroute to to the same locatino as the air sensor, or put a filter on it. (which can smell a bit more), or an oil catch tank, as on boost it may spit out goo, instead of just fumes.
- Fuel pressure hose. That is also present on the SC manifold. (make sure to use a vacuum type hose)
Posted 08 January 2012 - 08:05 PM
Posted 08 January 2012 - 08:42 PM
Did you make that bracket for the map-sensor yourself?
No, exmantaa who did the conversion made it.
Where do you put the air sensor? Do you make a hole in the slicone pipe?
No, i have a 70mm piece of pipe between the silicon hose on the throttle body and the air filter. Drilled a hole and put it in there.
There is also a small brass connector on the inlet (in the middle of all the injectors) Is that used for something?
Yes, that's the fule pressure pipe i mentioned earlier. That goes on fule pressure regulator which is on the end of your fuel rail.
The valve cover breather. Would in be nice to breathe the oil catch tank to the inlet to get rid of the fumes?
yes.
Posted 08 January 2012 - 10:15 PM
Posted 08 January 2012 - 10:17 PM
Posted 08 January 2012 - 10:27 PM
Use more force
Yes the brass pipe is for the carbon canister vent valve
Posted 08 January 2012 - 10:48 PM
The carbon canister vent valve, is that the hard plastic pipe with the wierd square connector that is always in the way of my supercharger pulley on the other side of the engine?
Posted 09 January 2012 - 09:22 PM
Posted 09 January 2012 - 09:39 PM
Posted 09 January 2012 - 09:46 PM
Posted 09 January 2012 - 09:47 PM
Posted 09 January 2012 - 09:48 PM
Posted 09 January 2012 - 09:52 PM
Posted 09 January 2012 - 10:17 PM
Posted 04 June 2012 - 11:13 AM
Of course the gasket goes on, before putting it on the engine:
A couple of question about this.
I have been reading something about modifying the gasket before putting it on. Did you do this and if you did, how?
What is all that blue stuff in the middle of the gasket?
Did you use some kind of gasket-seal to glue the gasket on the manifold?
Posted 04 June 2012 - 12:40 PM
