Living With And Running Costs Of The Noble
#61
Posted 06 February 2012 - 09:55 AM
#62
Posted 06 February 2012 - 01:16 PM
#63
Posted 07 February 2012 - 06:34 PM
'Cliffie', on 06 Feb 2012 - 09:55 AM, said:
So the bolts are just there for show and the wheels are not split rims...
...why?
Not sure why they settled on that design but the are loads of alloys available the do that. Many have removed the bolts when acid dipping then not put anything in the holes. I thought id put the extra effort in though
#64
Posted 07 February 2012 - 07:26 PM
Edited by westie, 07 February 2012 - 07:32 PM.
#65
Posted 08 February 2012 - 08:34 PM
#66
Posted 09 February 2012 - 03:11 PM
#67
Posted 09 February 2012 - 03:23 PM
#68
Posted 09 February 2012 - 03:49 PM
#69
Posted 10 February 2012 - 08:53 PM
Lights flashed but no noise. Noise when you press it again though to lock.
Decided ot couldnt be a door fault as neither worked.
So, dove into the passenger footwell and removed this
Opened it up and it looked like this
On the lower right of the circuit board it was all corroded (id cleaned it off a little by this pic). Doing a continuity check it seemed that there was a break in the thin strip near the copper coloured corner.
So, bodge head on. I soldered a small wire on the bipass the break.
Results is, it works again. Its just a temporary measure as ill get a replacement. Cheapest i can find is here so far
http://abacuscaralar...ced39e4ab5e4253
Anyone know where i can get one cheaper?
#70
Posted 10 February 2012 - 08:57 PM
#73
Posted 11 February 2012 - 06:02 PM
#74
Posted 11 February 2012 - 07:09 PM
#76
Posted 11 February 2012 - 08:41 PM
#77
Posted 11 February 2012 - 08:56 PM
#78
Posted 11 February 2012 - 09:06 PM
#79
Posted 11 February 2012 - 09:30 PM
'turbobob', on 11 Feb 2012 - 9:06 PM, said:
Pcb repairs are perfectly acceptable to ipc standards provided they are done right. I could get that done quickly for you if you like.
Ill keep that in mind if i get one for cheap, fit that then send you the tits one. Without that in the car there is no way to lock it haha :/
#80
Posted 11 February 2012 - 09:54 PM
