Living With And Running Costs Of The Noble
#121
Posted 16 March 2012 - 09:46 PM
#122
Posted 17 March 2012 - 07:52 AM
The original gto was a 2.5 v6 at 310 bhp.
The differances on the outside are the headlights, wheels although alot may of had their wheels changed and the exhausts exited through the rear floor (again many may of had an exhaust fitted from a later model by now and exit above the diffuser.
Looked like these
About 85 were made.
Next they brought out the gto-3
All had the same wheels. Most had the same headlights although i think some had the headlights mine had.
So only way to tell is the exhausts (not fool proof) or the badge. These were a 3ltr v6 hence the 3 part of the name.
352bhp and about 116 made
Next was my model, the gto-3r.
Hedlights and wheels were changed. Leather was standard and so was a 6 spd box and LSD.
Again 352bhp and around 150 made.
Final one was the m400, on the outside the differance was the ears in front of the rear wheels.
On the inside it has less turns in the steeeing, seats closer together, bigger turbos, an anti roll bar and a few other bits.
415bhp and 75 made.
All the bhp figures are hit and miss though as many have been modified and even just changing the exhaust releases about 30bhp on my model.
Interesting stuff - I had no idea that they were all such low volume!
#123
Posted 23 March 2012 - 10:33 PM
#124
Posted 26 March 2012 - 10:56 PM
#125
Posted 06 April 2012 - 08:39 AM
Its a job i detest doing as i normally just run a sponge over it but thought i would go a little deeper. About 10 minutes in i regretted ever starting.
Looks a little shinier now though.
You can see my newly painted calipers too
Then came to move it to one side of the drive. Would it start? Would it chuff.
Immediate thought was because of the washing so lifted the rear clam and yup the rocker covers had water on them. Dried it off, took all 6 coil packs off and used some electrical spray. No change.
Took everything off again. The sparkplugs were drenched in petrol and a little rusty, so i dried them out using the gas stove. Then unplugged the injectors and tested each plug and coil to make sure they worked.
Then put it all back together and hey presto, life on the first touch.
I dont want to drive it now though but i feel asthough i must
#126
Posted 06 April 2012 - 03:15 PM
#127
Posted 09 April 2012 - 01:39 PM
Who needs wind tunnel testing when you have rain?
#128
Posted 09 April 2012 - 01:59 PM
#129
Posted 09 April 2012 - 02:17 PM
#130
Posted 09 April 2012 - 02:38 PM
#131
Posted 09 April 2012 - 10:06 PM
Calipers before
Calipers after. All 4 are the same
Splitter smoothed as it needed a little tlc
Primered
And after gloss black today. Its getting 1200 wet n dried tomorrow then a couple of coats of laquer
Also started getting some stuff ready for its service next month.
10 litres of Shell Helix Ultra for £55 as the sump takes 8.5 litres
6 NGK BR7EFS Spark plugs. Very almost only bought 4 :/
New fuel filter ordered at £60 :/ Looks like this
Then going to pick up an oil filter from Ford tomorrow.Also going to pick up a new anti rollover valve and a relay and some wiring for the fuel pump. They are known issues that i want to make sure are done. The ARV sticks and causes a vacuum in the tank and problems relating to that.The fuel pump gets its power from some piddly wires from the ecu. This causes a problem at high RPM where the pump doesnt get enough voltage and therefore the engine can run lean. The fix is to use the little wires to activate a relay which sends power direct from a decent positive source
Edited by zoobeef, 09 April 2012 - 10:10 PM.
#132
Posted 10 April 2012 - 09:54 PM
#133
Posted 10 April 2012 - 10:05 PM
#134
Posted 10 April 2012 - 10:25 PM
#135
Posted 11 April 2012 - 07:53 AM
#136
Posted 11 April 2012 - 08:05 AM
Oh crap
How would you rate ownership so far Mark? It has really given me an insight into ownership of a car that's always been on my list of cars to own.
#137
Posted 11 April 2012 - 09:11 AM
and that is with you doing all of the work....deep pockets if you can't do mechanical stuff!!
Indeed, i would of thought a good couple of £k in labour if a specialist was doing it :/
Going to see if i can get a look at the rear manifold today to see if that needs replacing too.
#138
Posted 11 April 2012 - 09:15 AM
#139
Posted 11 April 2012 - 09:25 AM
#140
Posted 11 April 2012 - 09:28 AM
