Improving Heater
#21
Posted 27 November 2011 - 11:43 PM
#22
Posted 28 November 2011 - 12:20 AM
#23
Posted 28 November 2011 - 09:03 AM
#24
Posted 28 November 2011 - 12:44 PM
#25
Posted 28 November 2011 - 01:22 PM
#26
Posted 28 November 2011 - 01:42 PM
Try insulating the aluminium coolant pipes that supply the heater. They run down the RHS of the car.
If you take of the rear wheelarch liner off and the sill cover you can get enough pipe insulation to make quite a difference.
A very cheap easy mod and I now have to turn my heater down!
Gonna try this, is it hard to take the sill cover off? I heard its a pain. And could i just use wall insulation from work? lol
#27
Posted 28 November 2011 - 01:58 PM
The sill cover is just 2 screws, but the bottom part is doubles sided tape. Be carefull with that, as the sill cover cracks easy. Once of for the first time, don't re-use the tape part when putting back. Wheelarch lines is easy; just a few bolts.Gonna try this, is it hard to take the sill cover off? I heard its a pain. And could i just use wall insulation from work? lol
Edited by smiley, 28 November 2011 - 02:01 PM.
#28
Posted 28 November 2011 - 02:00 PM
What do you mean dont re-use the tape part. Do you mean use some new tape to stick it down?
#29
Posted 28 November 2011 - 02:02 PM
Yes. Easier in the future to get back in if needed.
The sillcover sits flush with just the 2 screws.
#30
Posted 28 November 2011 - 02:04 PM
Ah right cheers matey
#31
Posted 28 November 2011 - 02:10 PM
http://www.vx220.org...ng-improvement/
#32
Posted 28 November 2011 - 09:42 PM
Edited by GPA Signs, 28 November 2011 - 09:48 PM.
#33
Posted 28 November 2011 - 10:23 PM
Awesome. Glad it worked for you too! mine gets hot in about 3 mins now. Happy days.Thanks for the advice.. did it today, turned that part on top of the heater box, undid the clip and......yerrr warm... No Hot Hot Hot.
I'm like a pig in sh@t.
#34
Posted 28 November 2011 - 11:07 PM
#35
Posted 28 November 2011 - 11:08 PM
Before fitting insulating foam I plastered the heaterbox with silver gaffa tape.
It is possible to get foam to 3 sides of the heat unit without removal.
#36
Posted 28 November 2011 - 11:24 PM
Heat actually goes through that?
#37
Posted 28 November 2011 - 11:52 PM
Photo's as requested.
Is it safe for all that foam bunched up like that? It looks like no heat will escape from there tbh. Where did you get that foam from and the pipe if you dont mind me asking?
#38
Posted 29 November 2011 - 12:18 AM
#39
Posted 29 November 2011 - 07:32 AM
#40
Posted 30 November 2011 - 11:40 AM
Pipe comes from https://www.europaspares.com/
Foam is packing material we receive at work. It is actually anti static foam. Not sure how much is knocking around. Again if anyone would like some, just PM me and I'll have a scout round and see how much I can collect. I would estimate I used at least 1 square meter of the foam (obviously compressed now).
Kind regards, Paul
