Improving Heater
116 replies to this topic
#41 kingwowns
kingwowns
  • 688 posts
Posted 30 November 2011 - 11:56 AM
Fill the driver's sill with loft insulation. Pipe lagging is way too difficult to get into the cavity and feed it onto the pipe. You'll need access to both ends of the sill cavity to do this, but it's an easy mod.
Last winter I stripped the heater box and sealed it with RTV, then replaced the crappy metal hose (from box to cabin) with a silicone & stainless kit (ebay). No big difference, but I noticed that when tooling around at slower speeds, heat eventually trickled from the vents.....however, when at higher speeds (I get a 20 minute motorway blast to and from work each day, with few other road users around.....) all heat disappears. This suggests that the air passing over the car is cooling the heater circuit to the point that there is no more energy left in it to transfer.
I agree - the heat needs to get to the matrix in the first place! Lagging is a bit of a pain but do-able..
http://www.vx220.org...ng-improvement/
#42 Mangham54
Mangham54
    Wannabe....
  • 12,034 posts
Posted 30 November 2011 - 12:48 PM
I also found that lining the soft top made a massive difference. I also find that in my MX5 that heated heats make a big difference, as leather takes ages to warm up.
Limited edition. thumbsup
#43 smiley
Posted 30 November 2011 - 09:54 PM
They do popup once in a while thumbsup
http://www.vx220.org...soft-top-liner/
#44 davemate
davemate
    Harrop!!!
  • 3,228 posts
  • Interests:Provoking Badgers
Posted 30 November 2011 - 11:06 PM
Filter works a treat. It has virtually NO restriction. PM me if you want some material.
Pipe comes from https://www.europaspares.com/
Foam is packing material we receive at work. It is actually anti static foam. Not sure how much is knocking around. Again if anyone would like some, just PM me and I'll have a scout round and see how much I can collect. I would estimate I used at least 1 square meter of the foam (obviously compressed now).
Kind regards, Paul
could you please let me know which bits you bought from the site, this looks like a really good fix.
#45 techieboy
Posted 30 November 2011 - 11:14 PM
One of these works a treat. The convoluted tubing bends to exactly the shape you need and the two trumpets that come with it fit nice and tightly on the outlet from the heater box and the inlet to the air distribution plenum. Veritable bargain as well.
#46 davemate
davemate
    Harrop!!!
  • 3,228 posts
Posted 30 November 2011 - 11:19 PM
brilliant! that is my weekend plans sorted- seal up the matrix, wire in the heated windscreen and fit this.... and probably put the hard top on as well now.
chinky chinky
#47 wantsum
wantsum
  • 614 posts
  • Interests:Gaming and now fixing cars
Posted 01 December 2011 - 08:39 AM
i got one of these a few months ago when I first got the car , only thing you will have to do when
fitting the trumpet on heater box is cut the two of the rounded sides square as its a tight fit.
#48 davemate
davemate
    Harrop!!!
  • 3,228 posts
Posted 01 December 2011 - 01:19 PM
another reason for me to ask for a dremmel for Chrismas!
#49 techieboy
Posted 01 December 2011 - 01:22 PM
Sorry, yes, forgot about the trimming off the edge of the trumpet as I was doing it all off the car with a spare heater box and plenum. I found it easier to use a hacksaw than a Dremel in this case. thumbsup
#50 astravxr
astravxr
    Straight roads are for fast cars, turns are for fast drivers
  • 1,748 posts
Posted 01 December 2011 - 01:42 PM
Where would you get that insulation foam from? I've checked B&Q but they have nothing other than fibre glass etc... no foam :(
#51 wantsum
wantsum
  • 614 posts
Posted 01 December 2011 - 01:45 PM
:yeahthat:
#52 Paulus H
Paulus H
  • 2,063 posts
Posted 01 December 2011 - 02:21 PM
All the pipes and bends are from Europa spares. I would not really know where you could buy a square meter of the foam but I could probably find enough that is lying around at work for your needs. I can probably buy a square meter from one of our suppliers if you were stuck. Kind regards, Paul
#53 kingwowns
kingwowns
  • 688 posts
Posted 01 December 2011 - 05:08 PM
I used a grinding wheel which was fine - my pipe came in the post and it was a lovely red - trumpets as well!
#54 astravxr
astravxr
  • 1,748 posts
Posted 02 December 2011 - 06:45 PM
Well i've done what i could before it got dark. I took the wheel off etc but couldnt find where the pipe was? :blush: I took the sill off and cracked it a little on the side (getting carbon fibres ones anyway). Put insulation pipe around the pipes as much as i could then put loads of insulation foam stuff around the heater box, going out tonight so hope its better. Might try sealing the dash up a bit another day
#55 astravxr
astravxr
  • 1,748 posts
Posted 03 December 2011 - 01:31 AM
Been out and no difference. Only drove the car for 10 minutes, how long should it take for the heat to come through? at 10 mintues i could feel it getting kind of warmish
#56 davemate
davemate
    Harrop!!!
  • 3,228 posts
Posted 03 December 2011 - 10:21 AM
:yeahthat:
got the kit through today, which bit is it i will need to trim, or is is painfully obvious?!
(i havent opened up the box yet as i am still working, i just know it has arrived)
#57 davemate
davemate
    Harrop!!!
  • 3,228 posts
Posted 03 December 2011 - 06:38 PM
Fitted :) Out of interest, because my direction knob is stuck... I have turned it all the way with pliers. But would the cabin vent be on at all when it should be up at the windscreen?
#58 astravxr
astravxr
  • 1,748 posts
Posted 03 December 2011 - 11:05 PM
Erm yeah... been out for a good drive today and when the car is sitting still it starts to warm upish but when moving theres just cold air coming through, the faster i go the colder it is. Something wrong with the box or have i not put it back together properly when i sealed it?
#59 Whiteboy
Whiteboy
  • 6,950 posts
Posted 04 December 2011 - 09:52 AM
Did you flush out and clean out the heater box and have you bled the system post sealing?
Steve
#60 astravxr
astravxr
  • 1,748 posts
Posted 04 December 2011 - 02:34 PM
Steve
How do you mean bleed the system? i did this about 2 month ago mate. I cleaned the box out and then sealed it but just connected the pipes back on and topped the water back up at the header tank.
Its weird how its cold when driving but when sitting still it gets warmish. Maybe i've done something to one of the flaps?
