Dg Vx220 Turbo Full 80Mm Intake Kit - Airbox / Amm / Recirc
Started by
Duncan VXR
, Nov 29 2011 08:51 AM
90 replies to this topic
#81
Posted 02 January 2012 - 12:10 AM
Thank you thank you thank you!! haha. Ill sort it all out as soon as i get a new tank! I think an OBD 2 Diagnostic Scanner is in need too!
#82
Posted 02 January 2012 - 06:49 AM
Pic joe has posted if for the n/a engine and not the same as the turbo. Very easy to keep the light out for collant level. Will pm
#83
Posted 02 January 2012 - 11:42 AM
No offence dg but why would you want to fit a header tank with no coolant sensor....
#84
Posted 03 January 2012 - 11:30 AM
None taken sir - they will have a sensor, just reviewing different ones and was just stating I have some made up already without that I could post this week if required. Sensor is a nice to have and not on a lot of cars but will have the sensor option
Also have a min / max tabs inside for ease of checking levels
DG
#85
Posted 03 January 2012 - 04:36 PM
Any due date on both the tank with sensor and intake kit DG?
#86
Posted 10 January 2012 - 01:01 PM
any update dunc on the kit?
#87
Posted 10 January 2012 - 01:09 PM
Yes its ready to go now but trying to find somewhere that can do the silicon parts cheaper as atm the 90deg reducer 80>60mm is a chunk and also only available in blue or 4 week lead on other colours. Should be tested on the rollers by the end of the month which I am getting excited about
1st tests will be a stg 4 setup and garratt with my standalone
Prices with the current supplier of silicon
Once I can fully confirm prices and have tested the kit will post in the for sale section as per the rules
Thanks for everyones interest in the kit, just struggle to get as much time as I would like and of course have a bad arse vag engine waiting to go into lukes car lol
DG
#88
Posted 10 January 2012 - 01:32 PM
how much will the box be alone?
#89
Posted 27 March 2012 - 08:44 AM
http://www.vx220.org...ts/page__st__20
results from RR testing and some fitted pictures - for sale thread created hopefully today
DG
DG
#90
Posted 27 March 2012 - 10:00 AM
I assume this still retains std 63mm (2.5") ID throttle body. Thats the next project , 3" tb
#91
Posted 27 March 2012 - 11:04 AM
Only if its needed, at 375bhp 63mm is not going to be much of a restriction but only 1 way to find out
DG
