Posted 30 November 2011 - 10:50 AM
Posted 30 November 2011 - 11:31 AM
Posted 30 November 2011 - 11:34 AM
I did mine because wishbones were manky, and didn't befit the nice new Nitrons.
Then it becomes a 'while you're there' excercice which can become terrifically expensive.
In order of importance i would do the following (which do not require the suspension to be taken apart:
Toelink
HCB
ARB link (or droplink)
then you are going to take the suspension apart
Bushes
Ball Joints
Hub bolts
Suspension Bolts
Shimms
Hubs (if required - but you will, 'while you're there' )
If you're going to go to all that bother you might as well get the uprights, steering arms and wishbones blasted and coated. to look like this
You have lots of choices to make and everyone will have their opinon. None are wrong, since all are tried and tested.
Your first is probably what ethos you're going to adopt for the shocks. There are loads of threads on that on here and you may just need to take a view or go and try a few. You can't go far wrong with a set of fast road Nitron NTRs though for a meduim budget (circa £1250), go with a set of Nitron NSS or GAZ Golf if you want to go down. If you want to go higher, the CF kit is good with soft springs, harsh valving and rock hard ARBs or the Nitron 46s are your other option. All depends on application (see my first sentence).
Your second decision may lie with which toe-link kit to use. The choices are:
-Replace with new vxl part
-Elise shop uprated stainless kit
-Elise shop lightweight uprated kit (Spitfire kit)
-Elise parts kit
-There are a couple of other, in particular a nice lookng french kit and a Guglielmi one (never seen it)
I went with Elise shop's uprated one and have been very happy with it you can see it here:
Then you will need to decide what bushes to use.
-OEM
-Some form of Nylatron/powerflex/probush
-OEM copies
The advantage of the plastic inserted ones is that they don't require the suspension to be at ride height when the suspension bolts are torqued up. Some question of longevity and quality of those bushes, but lots have done plenty of miles and countless track days and been fine. expect a harsher ride, but may also report it to be more pleasant than std. I went for OEM.
If you can get your mind round that you're onto a good start.
Posted 30 November 2011 - 11:51 AM
Posted 30 November 2011 - 11:57 AM
Edited by vocky, 30 November 2011 - 11:58 AM.
Posted 30 November 2011 - 12:04 PM
Posted 30 November 2011 - 12:21 PM
Posted 30 November 2011 - 12:55 PM
Posted 30 November 2011 - 12:56 PM
Posted 30 November 2011 - 09:57 PM
http://www.seriously...efresh-kit.html
It stating that this contains;
1x full set of Seriously Lotus wishbone bushes
8x Suspension Ball Joints
2x Track Rod Ends
2x Our own Antiroll bar drop links
1x Suspension bolt kit including damper bolts.
Does anyone happen to know if the seriously Lotus wishbone bushes as the same as OEM. I read somewhere that you had to fiddle around a bit more with some of the bushes? I would be looking for a OEM like for like replacement.
I think JG does a nice set of new bolts, and in regards to the toe link I would be happy with the standard OEM part again.
Would that little lot be sufficient?
Posted 18 November 2012 - 08:33 AM
Posted 18 November 2012 - 08:39 AM
Posted 18 November 2012 - 09:08 AM
Make sure you're sitting down when you ask vxl for the price of a new set of shocks.
That bad then is it? I don't want anything other than a standard OEM st up. I just can't really see the point of going to all the hassle of replacing the bushes and bolts etc without replacing the springs and dampers
Bumping this ageing thread as its on the to do list for the new year. I can't find a price for oem springs and dampers. Surely you should change these at the same time as replacing bushes etc. I found the seriously lotus kit and was a bit surprised that it didn't include springs and dampers
Have you thought about putting Exige Bilsteins on instead?
http://www.elisepart...lstein-dampers/
http://www.elisepart...eibach-springs/
Plus a pair of lowering mounts for the front is required as they raise the height slightly.
Posted 18 November 2012 - 09:10 AM
Something crazy like 600 notes corner wasn't it?
Posted 18 November 2012 - 09:13 AM
It takes all of 10 minutes to change a damper, and doesn't interfere with the other parts which have been changed, so I can see why they'd keep the parts separate. Plus the market for replacement OEM dampers is very small.
Posted 18 November 2012 - 09:15 AM
I've seen these but my thinking is that the guys in Norfolk know more about setting up a sports car for fast road use than I ever will. I've had cars in the past that I've upgraded the suspension on and they were never as usable after as he OEM setup. It's such a perfectly balanced car I don't want to risk this by fitting an after market suspension set up that isn't specifically designed to complement the chassis and original design.
OEM shocks and springs would do me just fine, I'm not a power seeking track day maestro so am happy with the standard feel.
Posted 18 November 2012 - 09:32 AM
I'd give up drinking with Ken, if I were you. He's clearly having an adverse effect on you.
If you think that standard can't be improved on, take them off and send them to Bilstein and they will rebuild them for you at £100 a corner'ish. I'm sure they could also supply replacement springs or you could get similar from Faulkner Springs.
Posted 18 November 2012 - 09:34 AM
Also tagged with one or more of these keywords: suspension, refresh, NTR, Nitron
The Market Place →
Car Parts For Sale →
Oem Bilstein SuspensionStarted by Ni S , 02 May 2020 ![]() |
The Market Place →
Group Buy Room →
Nitron Damper Group BuyStarted by Matthew Bentley Racing Ltd , 24 Apr 2018 ![]() |
General Discussion →
VX220 Discussion →
Nitron Ntr Advice. Na / Turbo Swap - Suspension.Started by dstarz7 , 26 Feb 2018 ![]() |
The Market Place →
Quantum Shocks ,Started by turboluca , 09 Dec 2017 ![]() |
VX220 Discussion →
Winter Refresh DealsStarted by Matthew Bentley Racing Ltd , 02 Nov 2017 ![]() |
