#21
Posted 10 February 2012 - 10:08 AM
#22
Posted 19 February 2012 - 08:01 PM
Internal bracing is made, just needs fitting.
#23
Posted 19 February 2012 - 08:11 PM
#24
Posted 19 February 2012 - 08:17 PM
#25
Posted 19 February 2012 - 08:21 PM
#26
Posted 19 February 2012 - 08:28 PM
Ive got a spreader plate but need to muster up some sort of struts to the boot floor still but dont want to loose boot space. Are you going to loose much boot space? Will you still be able to stuff bits past the carbon tubes behind the lights?
Yeah, it'll just be a bit awkward. Imagine a 1.5in dia tube virtically upward that starts from about 6 in back from the bolt through the floor. I'll take some internal pics when I get it done (probably sat)
#27
Posted 19 February 2012 - 09:56 PM
#28
Posted 20 February 2012 - 09:13 AM
Forgive my ignorance but is that the GT type exige spoiler...? Looks good whatever it is
Similar but its about a foot wider and its carbon rather than plastic.
#29
Posted 20 February 2012 - 09:23 AM
#30
#31
Posted 20 February 2012 - 09:28 AM
What did you use for the end plates?
Bit of a cheat really. I laid some flat plate up on vacuum release film then put another layer of film on the top, then a piece of wood.....then an engine block. Its carbon/glass/glass/carbon in polyester so nothing special. The carbon skins are just there to make it loow pretty.
#32
Posted 20 February 2012 - 11:40 AM
#33
Posted 21 February 2012 - 09:29 PM
#34
Posted 25 February 2012 - 03:26 PM
Any photos of the internal bracing?
Here you go. Rear bolt on spoiler pylon bolts through pylon base - clam - spreader plate into the top of the carbon tube. The tube has aluminium plugs top and bottom with a steel thread insert in. The clam has a rubber pad under the spoiler and above the spreader. The tube is bolted to the bottom spreader which is tagged onto the clam boot floor bolt.
Pic hopefully showing all the alignment
Top spreader (and manky mildew, eaugh)
Bottom spreader
There is some minor movement when I hang on it (I'm 65kg). I guess thats because of the small contact area (tube is 1.5") and compression of the rubber pad. Its small bit its there. I might revise these at a later date.
Any comments on an improved version would be welcome.
#35
Posted 09 March 2013 - 07:09 PM
#36
Posted 09 March 2013 - 08:19 PM
quite like this spoiler where did you get this from?
Srsly?
#37
Posted 10 March 2013 - 08:19 PM
#38
Posted 10 March 2013 - 08:25 PM
Ryan, you've been missing for a while haven't you? Where have you been?
Oh and FLD made it him self *cough* read the thread *cough*
Also tagged with one or more of these keywords: not safe for GiGo
General Discussion →
Tuning & Modifications →
Bored Last Week (Nsfg)Started by FLD , 01 Aug 2012 ![]() |
