Aerodynamics, Why Are They Important?
44 replies to this topic
#1 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,515 posts
    "Yes, I built it"
Posted 01 December 2011 - 04:05 PM
Aerodynamics, Why are they important?
Aerodynamics is the study of gasses moving over and around a body in motion. This airflow also will affect the body’s movement through the flow. Aerodynamics is used on road vehicles in order to make them safer and maximise fuel efficiency. Aerodynamics is more commonly used in race car designs because of the higher speeds that the vehicles do. In race car design, the same principles of aerodynamics are applied, just with a slight twist. The shape of a race car chassis is remarkably similar to an inverted aircraft wing. When a wing is inverted it creates downforce (negative lift) instead of lift.
Road Car Modifications
Many modifications can be made to a production car in order to raise their aerodynamic efficiency. These modifications can range from being fairly in-expensive, to extremely expensive. The modifications that can be made are listed and explained below.
Spoiler
A spoiler is a device that slows and collects air causing it to stand still. The spoiler creates an area of high pressure replacing the normal low pressure over the rear of the car. This helps reduce the pressure difference between the top and bottom of the car in turn which in turn creates downforce and reduces lift. Spoilers have one major drawback, they increase drag.
Airdams
The easiest way to stop air stagnation under the vehicle is to block the air going there. This is done by means of an “Airdam.” An airdam is a spoiler placed at the front of the car at the bottom of the bumper. Airdams also collect air thus increasing drag although by stopping the drag created by the stagnation under the car, the airdam actually reduces the overall drag. It also creates a pressure difference between the top and the bottom of the front of the car creating downforce giving increased cornering grip and steering response.
Splitters
A splitter is very similar to an airdam in the way it works. Splitters are normally found on the bottom of the airdam. The splitter utilises the stagnant air caused by the airdam to create downforce.
Sideskirts
Side Skirts are needed on a car because the low pressure under the car won’t last long if air can just enter from the sides. Side skirts block airflow entering the underside of the car. The skirts are found between the front and rear wheels on each side of the vehicle.
Undertrays
Undertrays are a great way to reduce pressure under the vehicle and overall lift. Undertrays will not work alone. They must be used in conjunction with side skirts, airdams, and splitters.
Airfoils
Airfoils are the most common of devices for producing downforce. Airfoils (wings) use a pressure difference in order to create downforce similar to the way an aircraft wing works although instead of creating lift as an aircraft does, an airfoil creates negative lift.
Diffusers
Diffusers create the most downforce of all the modifications talked about. They create so much downforce that a lot of governing bodies for motorsports have banned them completely.
A diffuser is a device that expands the directions of the airflow thus increasing the pressure of the flow. The optimum angle for a diffuser is around 9.5° above horizontal. A diffuser located at the rear of a vehicle will also serve as a pressure reservoir to fill the void at the back of the car. Not only do diffusers create massive amounts of downforce but they can also significantly reduce drag.
#2 Nev
Posted 01 December 2011 - 05:28 PM
Where did you dig this up from Mark?
The statement "Diffusers create the most downforce of all the modifications talked about" is highly suspect. I think most people would agree it is less effective than a wing/splitter.
#3 mbes2
mbes2
  • 8,515 posts
    "Yes, I built it"
Posted 01 December 2011 - 05:56 PM
just found it via google... while having a read up on some other bits... thought it looked good, for a better understanding.. now on to "DIY wind tunnel" kit from ebay.... lol
#4 Noodle1791
Noodle1791
  • 520 posts
Posted 01 December 2011 - 06:14 PM
Good reading! I wonder if anyone told the Elise driver he had 5 car ramps behind him before he backed up! My god they were huge!!!
#5 2.2_na
2.2_na
    No Compromise
  • 6,323 posts
Posted 02 December 2011 - 02:37 AM
I hope you video that. :lol:
#6 Nev
Posted 02 December 2011 - 05:10 PM
Anyone can write some vague unsubstanciated disinformation on the internet like that.
#7 oblomov
oblomov
    oblomov
  • 3,853 posts
  • Interests:Mumblers
Posted 02 December 2011 - 05:29 PM
And very poorly written as well.
#8 MrSimba
MrSimba
  • 5,197 posts
Posted 02 December 2011 - 08:14 PM
Subtle... very subtle! :blink:
Bet Joe will be getting the ally sheet and a riviter out this weekend after seeing this this tho!!! :D
Edited by MrSimba, 02 December 2011 - 08:18 PM.
#9 techieboy
Posted 02 December 2011 - 08:15 PM
Sector111
#10 FLD
Posted 02 December 2011 - 10:30 PM
....and then he'll dremel the hell out of it :D
#11 Cookies220
Cookies220
  • 2,721 posts
Posted 03 December 2011 - 09:09 AM
I must admit I was surprised to read a diffuser is more effective than a wing! Personally, I don't believe that.
#12 techieboy
Posted 03 December 2011 - 09:20 AM
Ferrari's seem to get away with fancy diffusers and clever management of the air on the underside of their "road" cars, without resorting to stupid big wings or any wings at all in a lot of cases. No great big wings on 3' high pylons on a 458 or F430 Scuderia's. So don't dismiss it entirely. But, that's a result of designing it in properly, from the start. Most of the aftermarket blingstuff we bolt on willy nilly has either no effect, or very little effect.
#13 Vespa
Vespa
  • 685 posts
  • Interests:Cars
    Girls
    Food
Posted 03 December 2011 - 07:15 PM
Diffusers are extremely powerful aero devises and are the most efficient thing you can have on your race car because it operates directly over ground, unlike a rear wing for example which does not see the ground underneath it. downforce gained through the diffuser often comes with little or zero drag which is why its preferable to find your perfromance here. the rear wings on f1 cars for example are filthy, and if the fia ever allowed ground effect to be used again you would certainly see a reduction in the size of wings used. Just to give you n idea, with ground effect the f1 cars of the time saw efficiencies of circa 13:1. now the teams are lucky if they see 3.5:1. wings and other bolt on aero devises could never hope to ahcieve this :(
#14 P11 COV
P11 COV
  • 7,683 posts
Posted 03 December 2011 - 10:03 PM
And there's loads of unsubstantiated bollocks talked on here too. So I don't really see the difference between this and some of the 'know it all' experts that post regularly on this site with no proof of their so called expertise.
Edited by P11 COV, 03 December 2011 - 10:04 PM.
#15 luke.
luke.
  • 2,167 posts
Posted 04 December 2011 - 01:22 AM
Bring back ground effect F1!!! To go back with these turbos :lol:
#16 Winstar
Winstar
  • 4,264 posts
Posted 04 December 2011 - 12:23 PM
:yeahthat:
There are subjects I've now just given up responding to or correcting as I'm sick of 'internet exspurts' regurgitating sh1t they've read/heard/been told by someone trying to sell them somthing with little real knowlage or understanding of it.
#17 RobNA
RobNA
    RobSC :)
  • 2,856 posts
Posted 04 December 2011 - 12:50 PM
:yeahthat:
:yeahthat:
#18 Tail slide
Tail slide
  • 241 posts
  • Interests:Fast road cars, trackdays & sprints, snowboarding.
Posted 04 December 2011 - 01:31 PM
If you're fed up with the bull and can handle some techy stuff, with many cfd pics, thorough explanations, calcs and photos from all types of motorsport....
Simon McBeath's main job is developing cfd analysis & building all types of aero devices for a wide variety of racecars, measured at MIRA windtunnel and then seen through to success on track, especially single seaters at speed hillclimbs which is where I know him from.
Some things were obvious, but many more were surprising, especially the complex choices of maintaining aero balance vs. maximising flow/drag vs. reducing lift, plus all the interplay between components like diffusers & rear wings.
Fascinating stuff and quite readable, unless you've had a beer or two....
#19 Boombang
Boombang
    Saxo boy
  • 3,022 posts
Posted 04 December 2011 - 02:26 PM
:yeahthat:
:yeahthat:
Perhaps the one and only time I want the 'Like This' button to work on this forum.
There are a couple of experts on here who's posts I can't actually read for cringing.
#20 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 31 October 2014 - 05:08 PM
Have anyone done any measurement on a VX and looked for gained downforce with different aero mods? BR, Per
